dana 24 to np 205 swap
I yanked my dana 24 out of my 71 F-250 4WD hiboy. It was making a ton of noise at higher rpms(highway speeds), and kicking out of gear. I've cleaned it off and haven't peaked inside yet. If there's any gears broken I don't want to spend a ton of money on the thing. The question is, will a np 205 be a direct fit? I've got a 390 with a np 235.
Should be an eazy swap. The 24 is a good case.That and NP435 are the only stock pieces left on my truck.
1972 Ford F-250 4x4 Dana 60/14 Bolt
4.88's, detroits, 40" Hawgs, rear PTO
winch, 390 c.i., N.P. 435, Dana 24
