Won`t start warm
Won`t start warm
Hi,have a 94.5 di,a little over 200,000 kilometers.Starts good cold,won`t start when warm,turns over good and will roll start when warm but need to leave sit for aprox half hour to start with key.Runs good when going.Just replaced lift pump and fuel filter to correct problem but no change.In the last few years truck sits without running on a regular basis.Fuel is fresh.Any imput appreciated,thanks.
http://cw-diesel.com/LuxSite/IPRInfo.htm
This is a link about the IPR. It is located on the high pressure oil pump(HPOP). It is in the engine valley to the front, right in front of the fuel filter housing.
I too had this same problem. What my problem was is the hpop (high pressure oil pump) the pump was going out after driving and warming up the engine the oil would develop air or foam. with this air or foam the starter would not turn the engine over fast enough develop enough pressure to fire the fuel injectors if the truck sets for a period of time the air would pop to the top of the oil and it will start.
after driving your truck check the dip stick looking for excessive air droplets or foam. it is also possible you just need to chage your oil and service it. may also add a defoamer to the oil, just a suggestion
good luck
good luck
wdsloot2
04-24-2013 12:02 PM
BlackJeep
22
10-21-2008 03:08 PM
Timken
24
01-29-2004 08:40 PM
