Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 01-26-2006, 10:32 AM
MinutemanCO MinutemanCO is offline
Garage is empty, add now
MinutemanCO is starting off with a positive reputation.
7.3 Throttle Response Problems
I'm new here and a bit of a novice when it comes to diagnosing mechanical problems.
I own a 2000 F250 7.3 Powerstroke 4x4. The only aftermarket engine modification I have is a Tymar intake. The problem I'm having started about 6 months ago in a very erratic fashion. I would pull up to a traffic signal and as the light changed to green, without warning the truck would have no throttle response. The engine was running fine; there was just no response as I stepped on the accelerator pedal. Usually when I put the transmission in neutral, revved the engine a few times, the throttle would come back on line. This happened 4 or 5 times over the summer and then went away completely until today. Today it came back with a vengeance. At one point I had to shut the engine down completely to restore throttle response. It’s a bit unnerving when it happens in the middle of a busy intersection.>>
I was told that it may be the throttle position sensor. Does this sound correct and does it need to be replaced?
  #2 (permalink)
Old 01-26-2006, 11:47 AM
sc93f's Avatar
sc93f sc93f is offline
sc93f is starting off with a positive reputation.
Sounds like the position sensor or IVS is acting up. Do you get an SES light when you push the pedal and get no response? I sprayed some contact cleaner on my IVS last year and it has been fine since. IF you can get a code number, it will isolate which part of the pedal assembly is acting up.
__________________
Scott
1999 Ford F250 CC SB 2WD PSD Donaldson Air Filter, CCV Air/Oil Separator, Coolant Filter, 203° Thermostat, Line X Bedliner
  #3 (permalink)
Old 01-26-2006, 12:20 PM
Please pardon my ignorance (I even tried to look up the acronyms you've used in the List of acronyms used here on FTE thread)...
What do IVS and SES mean? I do get a check engine light at the time of the problem. The light goes away though when throttle response is restored.
MMCO
  #4 (permalink)
Old 01-26-2006, 12:32 PM
Craig64 Craig64 is offline
Craig64 is starting off with a positive reputation.
SES = Service Engine Soon light
IVS = ?
__________________
01 F250, 2WD CC, 4" Fabtech lift & level, Tymar intake, tri-pillar guages,Tru-Cool 4379, 4" ANSA stainless exhaust, DP-tuner 6 position, Firestone air springs, ITP HPX, Oilguard, ITP Regulated Fuel System, Airdog, LL injector delete, coolant filter, new PCM, mag-hytec tranny pan, 160k miles,
  #5 (permalink)
Old 01-26-2006, 12:33 PM
akfalconer akfalconer is offline
akfalconer is starting off with a positive reputation.
IVS-Idle validation switch SES-service engine soon
As to to your problem I think the above poster's advice is a good place
to start.The whole go pedal is electically controlled and is known to
fail.Do you have access to a diagnostic tool?
  #6 (permalink)
Old 01-26-2006, 01:06 PM
I don't have access to a diagnostic tool personally. My only option at this point is to come as close to a diagnosis as possible prior to bringing the truck to a mechanic to read the codes.
  #7 (permalink)
Old 07-20-2006, 07:06 AM
fcdoiron fcdoiron is offline
fcdoiron is starting off with a positive reputation.
I too have the same problem where the check engine light (MIL) comes on, and the engine still runs at idle, but their is no throttle response. If I depress the gas pedal, this sometime resets the check engine light and I can proceed on my way. This used to happen infrequently, but is now happening so often I can drive for more than a few minutes. I have an ACTRON 9145 scanner, but it does not read any codes associated with the light!!! I am going to replace CPS based on other comments I've read, but I would like to know what your final solution worked out to be. Thanks.
  #8 (permalink)
Old 07-20-2006, 07:40 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Well, here's an interesting new development.
www.ford-parts.com offers a replacement Throttle Position Sensor for $41.54.
At that price it's cheaper to just buy a new sensor and install it to see if that fixes it than it is to pay a shop for the diagnosis.
http://www.trademotion.com/partlocat...99&catalogid=1
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #9 (permalink)
Old 07-20-2006, 07:41 AM
1999 Ford F-550
Hmmm, I just thought of something, that sensor may be for a gas engine. I'll go check it out some more.
__________________
Dan
  #10 (permalink)
Old 07-20-2006, 07:44 AM
1999 Ford F-550
Yeah, sorry guys, I would write them or call first before ordering that part, I think it's for a gas engine. It would pay to ask if you need one, diesel pedal assemblies are more than twice that price.
__________________
Dan
  #11 (permalink)
Old 07-22-2006, 01:55 AM
corpuspits corpuspits is offline
corpuspits is starting off with a positive reputation.
Just fixed mine 450. it was the tps and a cut wire under the hood same problem you have and it got worse with time.Stealership fixed it about 3 weeks ago.They replaced the whole throttle assemble
  #12 (permalink)
Old 07-22-2006, 02:55 PM
ardvarkus ardvarkus is offline
ardvarkus is starting off with a positive reputation.
First Post. Have been collecting snippets over the years.
I had a CPS issue. Yours sounds like #2 below: (THis courtesy of some unknown post- perhaps flatratemechanic?)
1. Engine dies or runs rough intermittantly- Replace cam position sensor aka CMP. International part number 1825899C93 is latest version I have part number for.
2. Engine defaults to idle from any rpm and throttle no longer responds unless engine is shut off and restarted- Throttle pedal assembly related, almost always due to a conflict in readings of the idle validation switch and throttle position sensor. Ford uses a microswitch as an idle validation switch, it is part of the throttle pedal assembly and dust/dirt/lint/toe jam etc can cause the microswitch to stick intermittantly causing default to idle. Clean the switch with some electrical contact spray or replace as needed, Ford doesnt sell the switch separately and the complete throttle pedal assembly must be purchased.
3. Low power complaint when engine first started when cold. TC P0470-P0478. The engine backpressure control solenoid in the turbo pedestal starts to leak internally allowing oil pressure to close the turbo exhaust valve cutting off exhaust flow. Disconnecting the actuating rod is a temporary fix but the back pressure solenoid eventually starts to leak oil externally and turbo pedestal replacement is only cure. Also International has come out with a retrofit turbo up pipe kit to eliminate those pesky exhaust up pipe leaks at the turbo Y manifold donuts, I dont know if these also fit corresponding years of the PSD.
  #13 (permalink)
Old 07-22-2006, 05:24 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Welcome ardvarkus. Good first post.
__________________
Mike
2001 Auto Crew Cab 4X4. 38R and Swamps Hybrids. Transgo and diode Tranny. 400HP but not really. 05 front end and stickers makes it faster.
  #14 (permalink)
Old 07-25-2006, 12:51 PM
No Throttle Response
The dealer pulled the code P0221, which I was not able to with my scanner. You are right, the engine would idle and not accelerate due to a bad foot pedal assembly. Part cost $49.00 at the dealer. Since the powertrain was still under the 5 yr/100,000 mile warrantly, I only had to pay the deductible of $100.
Now it looks like I have problem #1, it won't idle while in drive, so I am planning on replacing the CPS.
Thanks for your help.
  #15 (permalink)
Old 04-29-2009, 09:51 PM
mike94560 mike94560 is offline
mike94560 is starting off with a positive reputation.
My 2001 F250 7.3L diesel has the dreaded P0221 code. No throttle response. Idle is fine.
It is getting worse. New PCM but still not working. IVS works fine when I checked it with an analog multimeter. So I have to bite the bullet and have the dealer run diags on it.
On a side note. My F250 was recalled for the CMP. It already stranded me. They put in a new one in 2005 but now, 2009, a recall replaced even that part with a redesigned one.
Does Ford make anything electrical that does work????
Tags
73, code, engine, f250, ford, issue, p0221, pedal, position, power, replace, service, stroke, throttle, truckp0221
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
