Inverted Y to T style steering on 76 f150
Old 01-18-2006, 05:02 PM
tobmasterp's Avatar
tobmasterp
tobmasterp is offline
I'am going crazy trying to find information on this, many have done this with the 76 bronco using 78-79 parts but they are a completely different body style so that doesn't help me. I have a 76 f150 4x4 and am replacing alot of it. My steering links/joints are all messed up, so I was going to replace them, but I want the ability for a drop pitman arm to get the correct geometry for the steering.
So the question is: does the t style steering from a 78-79 f150 bolt directly to my current 76 setup so I can do away with the Inverted Y and the lack of drop pitman arms or are there some slight differences that need to be overcome?
Old 01-18-2006, 06:16 PM
teds74ford's Avatar
teds74ford
teds74ford is offline
Supposedly they are a direct bolt on. I am looking at doing a GM 1 ton Tie rod conversion since it is about the same price as parts from LMC, JBG and the like. However, if I went stock, I would use a superlift adjustable drag link so that fine tuning the alignment would be possible. Hope this helps.
Old 01-18-2006, 07:33 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
Hmm, is the current set-up the power assist or the integral box? I took a 78/79 set-up to replace the power assist on my '74.
The first diff between the two is the steering gear placement:
The '74 manual gear is forward of the drag link, pitman arm pointing toward the driver. The power steering gear mounts directly above the drag link, pitman arm pointing toward the front bumper. I took the intermediate shaft to the column for an easy fit-up.
The frame of the '74 is not flat where the new gear will mount. The new gear orients to the track bar bracket. This puts 2 of the 3 mounting holes directly over a contour. I'll be grinding some spacers to fit the contour so that I can maintain surface contact when it's torqued down.
Another difference is the drag link:
While both are the "T" style, they mount differently. The '74 mounts from the bottom up, nuts on top of the steering knuckle. The 78/79 drops in from the top, nuts underneath. The ends are different, newer has bigger diameter bolts with (I think) a different taper.
This is where I stopped. Had I taken the newer knuckles and everything associated with the disc brakes it'd be a done deal. At this time I prefer to keep the drums, I'll have to find a reamer with the correct taper (whatever that is) and fill the bottom of the old taper.
The hoses may have different fittings. I planned on taking the stuff I need to my local NAPA so they could cut hose and make the high pressure crimps if need be. I want new hoses anyway.
Hope this helps, Mike
Old 01-18-2006, 07:43 PM
1977f250's Avatar
1977f250
1977f250 is offline
I had a 1977 f150 4x4 and put it all on from a 1978 f150 4x4 and all fit well with no mods.
Old 01-19-2006, 12:22 AM
yeha4x4's Avatar
yeha4x4
yeha4x4 is offline
I just did my 76 f150 4x4 a few months ago and yes the 78-79 parts bolt in no problems.
Old 01-19-2006, 07:04 AM
77460f150's Avatar
77460f150
77460f150 is offline
I did this on my 77 F150 4X4 last spring. I purchased new parts from Napa for a 79 F150, drag link, right tie rod end, left tie rod end, and adjusting sleeve with hardware. I bought the 4" drop pitman arm from BDS and bolted it all in place for about $325. Made a huge difference in steering play and took about an hour to install. Well worth the money and effort! -Ed
Old 01-19-2006, 10:44 AM
tobmasterp's Avatar
tobmasterp
Hey guys thanks for the response, I had a feeling it should work, I was just double checking before I went out and purchased the items.
Old 01-19-2006, 11:36 AM
1975Ford's Avatar
1975Ford
1975Ford is offline
I did the same inverted T style steering conversion on my 1976 F150 4x4 and 1975 F150 4x4. You will need all the 1978-1979 F150 steering components from the pitman arm down to both tie rod ends. 77460f150 listed all the parts.
This would be a good time to replace all the bushings from the radius arm to the C-bushing, including the track arm bushing. A kit will include all the bushings.
Old 12-28-2012, 08:14 AM
fordman50's Avatar
fordman50
fordman50 is offline
Interesting, I used to have the T style but now have the Y style on my 77 and it is WAY tighter. I drive on a lot of twisty country roads and I feel a lot safer and connected to the road with the stock set up. The T style also lowers your clearance and was a step backwards in technology on my opinion.
Old 02-05-2013, 03:35 PM
sxviper912's Avatar
sxviper912
sxviper912 is offline
Do all 77s have the y style and how do u tell the difference
Old 02-05-2013, 03:38 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Garrison Power Assist P/S: 1973/75 F100 4WD / 1975 F150 4WD
Power Assist: 2 long P/S hoses, pressure & return, route from the P/S pump to the P/S control valve. Two short P/S hoses, pressure & return, route from the P/S control valve to the P/S hydraulic ram cylinder.
With Power Assist, the manual steering gearbox is used, because it has nothing to do with Power Assist.
Ford integral P/S: 1976/79 F100/150 4WD. P/S pressure and return hoses route from the P/S pump to the P/S gearbox.
1965/77 P/S pumps have a steel reservoir, P/S pressure hose threads on.
1978 and later P/S pumps have a plastic reservoir. P/S pressure hose has a straight tube w/an o-ring on it. Connects to the pump w/a qwik connect fitting.
Old 02-12-2016, 07:41 PM
YooperUno's Avatar
YooperUno
YooperUno is offline
Hi there 77460f150 this system you put on your truck did you have a lift on it, Im going to convert mine and I only have a 2" lift on my truck and wondering if I should put a drop arm on mine tks yooperuno
Old 02-12-2016, 08:42 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Zombie Thread ALERT !
Hey Yooper.. just so ya know 77460f150's last activity was in 2011. There's a chance he/she might reply but don't have too a high a hope. Let's keep our fingers crossed....
IMO, a dropped pitman arm isn't required with a 2-inch lift. Btw, are ya just leveling it out by lifting the front or lifting the rear too?
Old 02-12-2016, 09:48 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
I converted my '77 F-150 4x4 from inverted Y to T style of '78-79 F-150 back in 1986. HUGE improvement. You will need the whole deal between the steering box shaft and the steering knuckles. That includes pitman arm, drag link, left (short) and right (long) tie rod ends, adjustment sleeve and two clamps.
I agree ..... only 2" lift ..... no need for a drop pitman arm or track bar relocation bracket. If you put a drop pitman arm on it, you'll want to move the frame end of the track bar down a like amount. The 78-'79 stuff is intended to place the drag link parallel to the track bar so that they swing through the same arcs over bumps, rises, dips ..... so no "bump steer" occurs.
Much better set up!
Old 02-13-2016, 07:45 PM
YooperUno's Avatar
YooperUno
I lifted the front and the rear also just wanted to lift it a little didn't want to lift it up much. So all I have to do is buy the pitman arm for a 78 model and the rest the stuff also
Tks for the reply HIO Silver for the reply
Quick Reply: Inverted Y to T style steering on 76 f150
