'67 240 fuel pump problems
Old 01-18-2006, 01:25 PM
FOGHAT64's Avatar
FOGHAT64
FOGHAT64 is offline
I am having problems with getting fuel to the carb. I have changed the fuel pump, filter. Blew the lines out. When I first start the truck the lines and filter fill up and will idle if choked. When I press the accelerator it empties the line and filter and will not run.
Old 01-18-2006, 04:42 PM
97f3504x4ps's Avatar
97f3504x4ps
97f3504x4ps is offline
Check the rubber fuel line that goes from the frame to the fuel pump, have had them leak and suck air, thus not delivering enough fuel. If you have the old fuel filter that screws into the carborator these become cloged and not enough fuel to carb bowel to run truck. Its a good idia to replace it even if you can blow threw it, the filter that is. I have poked them threw with a scew driver just to get me home when they become cloged.
good luck.
Old 01-19-2006, 05:50 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome FOGHAT64, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 01-19-2006, 06:57 AM
FOGHAT64's Avatar
FOGHAT64
FOGHAT64 is offline
Thanks for the reply. I will check the line to the fuel pump. I didn't think about that, because I took the output line off the pump and it pumped gas to the inner fender. I have changed to an inline clear filter. I will check all the rubber lines.
fordf1501991
19
05-30-2019 06:32 PM
TripTheDog
11-13-2013 09:32 PM
Myfreeford
01-11-2012 10:07 AM
AFoster1025
1997-2006 Expedition & Navigator
10-25-2010 05:48 PM
Kennebec
08-10-2003 08:54 PM
Quick Reply: '67 240 fuel pump problems
