help 1996 OBDII port location
Old 01-17-2006, 08:44 AM
mikejack's Avatar
mikejack
mikejack is offline
Search done.
I have a 1996 F250 and I can't find the OBDII port. I've looked everywhere under the dash. Anybody can help out with the location?
Thanks
Old 01-17-2006, 08:50 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
The F250's (over ~8500 GVWR) didn't have to go OBD-II at the same time as the F150's, so your truck is probably still OBD-I and has the diagnostic port under the hood.
Old 01-17-2006, 09:13 AM
mikejack's Avatar
mikejack
mikejack is offline
Yes it is a HD f250. Probably still OBDI.
Thanks for the info
Old 09-16-2009, 06:57 PM
mavrik4x4's Avatar
mavrik4x4
mavrik4x4 is offline
Old thread, but seeing as how Im now dealing with this exact issue, I must say that this is the dumbest thing I have ever seen....even for Ford. Just got the truck and Im already sick of the Ford B.S.....OBDI on a 97.....gotta be fkn kiddin me.....
Old 09-17-2009, 07:08 AM
subford's Avatar
subford
subford is offline
OBD I beats the heck out of OBD II. I would not have a truck with OBD II.
Old 09-17-2009, 11:00 AM
mavrik4x4's Avatar
mavrik4x4
And why exactly would that be? OBDII systems allow much more specific failure information, including specific cylinder. It has better memory, and uses a much easier to read system then a series of flashes on the guage cluster.
Dont even get me STARTED on trying to custom TUNE an ECM after any serious modifications!
OBDI is just too limited. There is a reason it had such a short run before II came out.
Old 09-17-2009, 12:26 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
Blame it on the feds, not Ford. Anything under 8500 GVW had to go OBD-II while anything over 8500 GVW didn't, so ford had to go OBD-II on F150s.
Old 09-17-2009, 01:07 PM
subford's Avatar
subford
subford is offline
Easier to work on.
OBD II systems are too complicated.
So does the OBD I system tell you a specific cylinder that is bad and what is wrong with it.
OBD I has all the memory I need.
Not true, the flashes can be read if you are out without your scanner as emergency back up. There can not be any easier system to read than the OBD I system.
The OBD I system is very good the way it is and you can write your own program to run it. Try that with an OBD II system.
I see you have no idea why they went to OBD II and it was not because it was too limited. You can make all kinds of changes to the OBD I computer program to run any modifications!
Old 09-17-2009, 01:19 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
OK, I see a simple solution here...... Just sell, or give away all the Fords you have that are OBD I, then spend the bucks to get LATER models that have your precious OBD II systems..
Old 10-19-2009, 09:36 AM
O's Fan Rich's Avatar
O's Fan Rich
O's Fan Rich is offline
So, even though I have a 97 F250HD and all the OBD1 readers say to 1995- I want to get the reader for a 95 and under OBD1.
Correct?
Old 10-19-2009, 10:38 AM
Jermafenser
Yes, correct.
Old 10-19-2009, 10:58 AM
O's Fan Rich
Originally Posted by Jermafenser
Yes, correct.
Awesome.
Thanks for the verification.
I'm gonna LOVE having this truck!!!
Old 10-19-2009, 02:31 PM
So-Cal Sancho's Avatar
So-Cal Sancho
So-Cal Sancho is offline
i have a 1996 f-250, 460 and it's obd 2. figured that out when i couldn't find the ports under the hood. it's got the port under the dash. also it's a hd_ over 8800 lbs. You can thank CA for that.
Old 10-19-2017, 06:09 PM
VF1000R's Avatar
VF1000R
VF1000R is offline
oh , it under the dash alright, passenger side , forward kick panel, 2 plugs, 1 Diag port , 1 Engine control port .
Problem is , they are Square 4 pin connectors. WTH ? neither of my SPOUT or OBD diagnostics connectors fit. WASSUP with that ??????
Old 04-03-2021, 08:15 PM
alanazon's Avatar
alanazon
alanazon is offline
Old thread, but my California 1996 F250 460 V8 also has an OBD II port under the dash, just on the passenger side of center, right in the open, facing forward and easily accessible, with just a black plastic cap over it marked "diagnostic port". Apparently OBD II ports really aren't supposed to be there, but I guess this happened before OBD II standardization. Have seen a couple of 1997s - the ones with the old "heavy duty" body style - here in Canada with the OBD II port in the same location.
mastapasta
06-21-2017 07:43 AM
AlbyVA
6.4L Power Stroke Diesel
12-19-2012 08:18 AM
liljohn
16
04-25-2011 09:32 AM
f-250 yooper
03-03-2009 02:03 PM
ltfire99
1999 to 2016 Super Duty
01-03-2008 07:05 PM
Quick Reply: help 1996 OBDII port location
