testing a block heater
I was wondering if there is anyway of testing a block heater to see if its working. I've been plugging my truck in on a timer so it comes on for 3 hours before I want to use it in the morning. I'm not sure if its working well. It seems to start the same whether i plug it in or not. Can you test the heater for continuity at the plug?? Any information would be helpful. It always starts even this morning with sub zero temps plus wind chill. I'm glad I put new batteries in it though have to crank it quite a bit to fire it up.
Received 3,180 Likes
on
if it is quiet where you are, you can hear the block heater after it is plugged in for a few. it sounds something like an old percolator coffee pot. hen i plug mine in, if i do it rite, i can hear the power "snap" when contact is made between the plug and extension cord.
the most common failure on the block heaters is the actual plug itself.
the heater and wire are good, it just needs a new plug.
First make sure the BH red power plug is in the BH, then do a continuity test with a meter on the main plug wires at the grill. If there is no continuity check the wires for breaks just behind the 120V plug. Pull on the wires and you can see the break as the shielding gets smaller, cut off the end. If the 2 power wires now have continuity through the BH just replace the 3 prong plug.
on
whenever i plug mine in it is at least overnight. there have been times that i have plugged it in, then did not use the truck, and forgot to unplug it. thing has sat for weeks nice and toasty warm waiting for me.
the upside to leaving it plugged in for at least 8 hours is the battery maintainer that is hooked up charges the batteries with the block heater. i use a multi plug extension cord to go through the grill, and the block heater is plugged into the extension under the hood with the battery maintainer.
Thanks for all the suggestions. A couple weeks ago I checked the cord that plugs into the bh. I unplugged it and cleaned the terminals. I then plugged it back in and I can hear it working now. I don't know if its running at 100% but it seems to be enough to help on the cold mornings. Which we surprisingly haven't had many of this winter so far. I think only 1 or 2 below zero mornings. Thats unusual for Feb. in Maine...
on
on
Every one I have ever plugged in and that is lots will spark and you can hear it and see it at night.
I might use a drop light to test it but I wouldn't use it to leave it plugged in they are not heavy enough.
Even at tenps way below 0 we just plug them 2 hours in advance they drive the electric bill up substancially.
jchooper2000
1999 to 2016 Super Duty
11-30-2014 09:20 AM
