coolant system flush
hi all, i have a 99f250sd, 5.4L. i want to do a coolant system flush on it, since i bought it used and want to know that it is fresh. my question is: do i need any special coolant from ford, or will regular prestone mixed 50/50 with distilled water work just as good. i know that some engines call for "special" coolants, and was wondering if the 5.4 is one of the. thanks in advance !!
what color os in there now???? green i assume.
the flush that engine remove the clamps on the upper and lower part of the radiator, drain it, then use a garden hose and flush the radiator from the top hole. next flush the recovery tank. just insert a hose into the tank and it will drain out the bottom hose. find the heater hose coming off the intake use the hose and force water thru the rubber hose until it comes out clear and also flush thru the manifold hole until the water comes out clear.
coolfeet
11-12-2015 09:17 AM
coolfeet
10-24-2015 03:55 PM
68bluebeast
1997-2006 Expedition & Navigator
03-08-2015 08:48 PM
