smaller turbine housing
It depends on the future plans for your truck. Are injectors in your future?? If so I would go with a 1.0 a/r. If not some say a .84 a/r works well. Also what do you do with your truck? Do you tow alot? I dont think .84 housing is real good for towing. To small and creates to much drive pressure when your running hard. I got mine from Dale @tymarperformance.
wow, that was a whicked fast response. i dont tow more than a pop up camper. not sure if there are injectors, id guess not. i really dont drive the truck hard. i barely ever take it over 2300 rpm or so before i shift. so you would suggest a tymar 1.0?? also, im not very mechanically inclided. is this something i would be able to install myself?
Originally Posted by 444dieselrod
I second the 1.0, just for the ability to step up to stage ones eventualy.
Call Dale, he will tell ya EVERY little thing about changing them out. I can PM you his number if you dont have it.
Diesel Rod
Diesel Rod
if you could, that would be greatly appreciated. am i also going to have to change my intake filter and tube? im just itching for an excuse to do so, im hoping this might be it. if so, any suggestions on that?
Brandon
ScaldedDog
01-02-2015 09:20 AM
iceage
09-17-2009 12:35 PM
