Tested Out The Suspension
Well, after I re-did my front suspension today, my d-shaft is now the proper length so I tested out some articulation on the truck tonite.
I found that I need to add some more hard line to my passenger side brake lines, but other than that the truck did very well for its first time being 4x4.
Hey speakin of gauges in my last post. When I order up my Auto Meter junk is there anything special I need to be aware of? As in electrical or mechanical gauges? Also, I don't have a speedo cable right now, how does an electric speedo work? Or do I get a mechanical? Any advice here would be greatly appreciated, as I hate wiring.
Mustange - better keep the color on the DL for a few more days
looks good... are you running a small body lift? also, I looked at the pics in your gallery, but see 2 diff setups for you rear, what one did you stick with?
this https://www.ford-trucks.com/user_gal...=80099&width=0
or this?https://www.ford-trucks.com/user_gal...=72371&width=0
and what springs are you running back ther?
