Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Advertisement
  #376 (permalink)
Old 04-19-2009, 10:16 PM
Deltat210 Deltat210 is offline
Garage is empty, add now
Deltat210 is starting off with a positive reputation.
I got some pics coming, I just did the fix this weekend, the first door is long and horrible, not to mention the bleeding hands, the second door, is well, better than the first. But I took some pics, hopefully they'll help anyone. I cant stand working in doors, too many holes, wires etc.
  #377 (permalink)
Old 04-20-2009, 07:34 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by JOHNNYRICH10 View Post
Hey guys, I took it apart again put the motor in RIGHT this time. And i just finished the second door. As far as Pop being rude, I am a grown up I can take it . i figured if i looked hard enough i could find the answer but I think i got it faster by posting the question then i would have going through 24 pages of posts.and seeing as i am trying to do these locks through my lunches and after work before it gets dark rude or not it actually helped I appreciate all the help. This is an awesome fix and it will save me alot of leaning over and unlocking the door for people.
Glad you got it working. I covered a long time ago in this thread marking the motor to get it correct. Guess how I found out. I feel your pain on this one. However we all need learn time. The .01 repair was my quick fix without soldering. Then I found I could put a small copper wire around the thermistor and it would work. If I do it again I will drill a hole through it and put the wire in and solder as a circuit board.
I do understand about not reading 300 pages of stuff. Just the guy thought process of "I don't read instructions or ask for directions" At least with the wife in the car. Guy thing !
  #378 (permalink)
Old 04-20-2009, 12:02 PM
While Im getting the pics ready, when I lock the truck for the night, come out in the morning, the remote doesnt work. Unlock the door manually, and push the power door locks, the remote starts working again for the day. Any ideas?
  #379 (permalink)
Old 04-20-2009, 12:09 PM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.
You might try re-programming the remote.
  #380 (permalink)
Old 04-20-2009, 01:13 PM
Ok, pics for the directions for the fix!!!
No worries, here it is.
WARNING: The following is long winded, but if you want your PDL's to work again WITHOUT spending any $$ read on.
I finally got tired of my non-working PDL's and decided to tear into my truck and find/fix the problem. There has been many discussions about possible issues and I have concluded that the majority of us are seeing actuator motor problems and not relays, switches etc. Ill start by saying the problem I have had is that when I hit the switch, the locks attempt to move and after repeated attempts, the signal appears to get weaker and weaker until nothing....I assumed relay or switch.....NOT THE CASE!
First I started by testing the signal at the harness plug to the actuator. Perfect. No issues here. Next I completely removed the actuator/lock mechanism
*Steps to remove from 99 Ford F-250
Remove upper trim by pulling it straight out
Remove door switches carefully by twisting from door panel
Remove bolt from behind switch panel (in this case, its a phillips screw)
Remove reflector from lower door panel w/screwdriver
Remove bolt from lower door panel
Carefully bump door panel UP, don't pull away from the door
The reason is the hooks on the panel itself
Carefully move weather panel by slowly pulling away from door, you can reuse the sticky if your careful
Remove 2 bolts that attaches outside door handle (1) through hole in upper door access gained by removing plug in door, and (2) using 7/16 wrench, removing bolt behind door runner
Remove 3 torx screws holding lock assembly in place
Carefully! remove latch bar from lower outer door lock
Carefully remove upper lock bar from outer door lock
Maneuver the lock assembly down to the larger opening in the door to gain access to cable and wiring plugs
Remove inside door handle cable from lock assembly using needle nose pliers. Maneuver lock assembly to release the ball end of the cable from assembly
Carefully remove two plugs from lock/actuator assembly
End of removal procedure, reverse procedure to install!
and bench tested them with 12V..Here lies the problem. The actuator acted the same as when in the truck. First I did a thorough cleaning of all of the mechanism so it works freely and still had the same results. Here's where it get's tricky. These things are built so that they are NOT serviceable. I had already decided that they were going to need to be replaced, so I decided to break them open for closer inspection. It comes apart relatively easily, but appears that It cannot be put back together once apart.
I drilled out two small rivets and then pried the case apart. As you pry the case apart you'll notice these small little plastic rods protrude up through the case cover. These rods are then "mushroomed" with heat through the upper case and then sealed with some kind of silicone. When you pry apart the case the "mushroom" head breaks off and the rod remains.
You can dig out the silicone and mushroom head with a pick. It comes out very easy. Inside you will find a very small motor and some gear mechanism. I believed the problem at first to be worn brushes or dirty commutator contacts in the motor itself.
You'll have to bend two little metal tabs out and pull off the brush housing on the back of the motor.
I cleanded the gunk off the brushes and took 1500 grit to the commutator contacts and reassembled the motor. The motor worked, but if you applied even a slight amount of resistance on the armature, it would stop the motor. It should have been WAY stronger than this. I was stumped until I looked a little closer at the inside of the plastic brush housing.
Inside you'll find a small, thin rectangular (thermal resistor relay, dodad, thingamabob??) pardon my ingnorance, but I'm not sure what to call it. All I know is that this little part is what keeps you from burning up the motor,
should you continue to press the switch once the lock has been actuated. It appears that this thing wears out over time and will not allow enough signal to get through to the motor to make it work. THE FIX. I am cheap. Since I had done so much work up to this point, I decided that I would go a little further and try to make it work without spending the $$. I have better things to spend my money on than actuators.
I took a small piece of aluminum foil and wrapped the "thing"
voila! Perfectly working motor! I sat there and operated the thing for 10 minutes including one or two times stopping the armature and holding down the switch to see what would happen.
The motor builds heat, but not much. Not enough to worry about. Now that I had a good working motor I decided I would try and reassemble the unit. The problem is you cannot glue the unit together as there is a rubber gasket around the perimiter of the case and if you tried to glue the rods into the case, you would not have enough pressure on the two halves of the case to keep the gears in place (these things actually apply a great deal of torque on the case)
What I decided to do is completely break off the plastic rods flush with the bottom side of the case and then drill out the bottom case and screw it together.
This worked perfectly. You'll need screws that are the same diameter as the holes in the top of the case to keep it from "wandering". Also the screws should not protrude through the back of the unit as some of the mechanism has some pretty close tolerances and a screw sticking through the back would not allow some of the mechanism to work (this can be remedied with a decent set of wire dikes or a hacksaw).
I know all of this is hard to picture, but if you do decide to try this fix, you'll see what I am describing here. The locks are back in and working flawlessly.
__________________
  #381 (permalink)
Old 04-20-2009, 01:29 PM
vettdvr's Avatar
A thermister is a heat activated resistor that works as a current limiter in a circuit. When the door lock is activated the thermistor is cold and will conduct enough amperage to allow the lock motor to activate. However if you hold the lock button the thermistor will heat, resistance will go up and current will be significantly reduced to prevent damage to the motor. Making a mod to the thermistor to be a straight conductor will work. WARNING. After this mod if you hold the door lock button down (I don't know how long is too long) IT WILL BURN out the motor and might cause other damage. So this is a good modification but if you have children , wife who holds the button long and you find the lock no longer works you know what happened.
  #382 (permalink)
Old 04-20-2009, 01:31 PM
Agreed, tell them to keep their hands off of them!
j/k, At that point, you would have to buy new ones, just hope the truck doesnt go on fire!!!
  #383 (permalink)
Old 04-25-2009, 06:45 PM
Homemade's Avatar
Homemade Homemade is offline
Homemade is starting off with a positive reputation.
1986 f-250hd
I have a 86 f250 with this problem.
Are the PDL's the same or at least the same fix as the newer models?
  #384 (permalink)
Old 04-25-2009, 09:10 PM
I dont know, being a 13 year difference, probably run on the same priniciple though.
  #385 (permalink)
Old 05-11-2009, 10:17 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 has a great reputation on FTE.EXv10 has a great reputation on FTE.EXv10 has a great reputation on FTE.EXv10 has a great reputation on FTE.EXv10 has a great reputation on FTE.
Tips on fixing actuator
When you take the actuator apart, just separate the halves and leave the 2 rivets in place, and pull the little motor out. Then you can drill a few holes around the edge and wire it back together with rebar tie wire etc.
You can get the 2 little tabs to raise by drilling a little hole next to the tab to get a grip with a little screwdriver, spade bit ,etc. If you break the tab off just add some good glue around the 2 pieces, drill a shallow hole next to the broken tab and whack the metal there with a hammer and screwdriver at 45*.
No need to mark motor and bell end. The part # is on bottom of motor and the connections are on the top of the bell.
No need fon pennies and wrapping thermistor, just cram some tin foil in the slot where the thermistor was and dab some glue across the top to assure that it stays in.
Go to the auto store and get a spray can of brake parts cleaner. Blast a shot into the brushes end and another one into the motor end. This is mainly achohol, toulene, and acetone, and it will instantly turn your motor into a new looking motor due the the air blast and cleaning power. Also it will dry before you can grab your can of compressed air.
Make a little tool to keep the brushes open so you don't bend the arms when you put it together. A stiff piece of cardboard cut about 5/16" wide and bent near the end will work. Put it between the brush arms by the dip in the bell, and slowly slide parts together, then pull the tool out.
On the liftgate for the Ex; only take the actuator out and not the lock mechanism by lifting the black tab and slide out. The lock will probably be stuck so put a big phillips screwdriver through the 3/8" hole and pry on the mechanism (after a dose of WD40 from all angles) after it's free wipe it off and shoot some white lithium grease from a spray can in it and work it some more.
  #386 (permalink)
Old 05-11-2009, 11:03 PM
priusron priusron is offline
priusron is starting off with a positive reputation.
If you bend a paperclip into a long U you can squeeze the ends together and put into the holes on the end cap and release it. It will then hold the two brushes apart so you can assemble the motor.
Ron
  #387 (permalink)
Old 06-06-2009, 12:28 PM
locknload223's Avatar
locknload223 locknload223 is offline
2000 Ford Excursion
locknload223 is a splendid one to beholdlocknload223 is a splendid one to beholdlocknload223 is a splendid one to beholdlocknload223 is a splendid one to beholdlocknload223 is a splendid one to beholdlocknload223 is a splendid one to beholdlocknload223 is a splendid one to behold
Well I followed the instructions to the tee while woking on my rear passenger door and it's still dead. I was careful putting the motor cap back on and even marked the case so I was sure it's orientation was correct. It doesn't seem like it's getting power, no vibration or sound (I did plug the electical connections back in). Any ideas? I guess I could see if I'm getting power to the pugs when the remote is pressed.
__________________
Mike, PAA Member #127
2000 Excursion Limited PSD- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, 6.0 intercooler, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, 6637, MBRP 4", AIH delete, 4" hanger, Vcodes/F350 blocks, Bilstein 5100s, Airbags, '08 diff cover, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights, Auto Enginuity.
http://i19.photobucket.com/albums/b157/locknload223/Excursion/004Medium-4-1-1.jpg
  #388 (permalink)
Old 06-06-2009, 05:45 PM
vettdvr's Avatar
1) Verify the plug has power by activating the door lock switch on the door
2) You can apply 12 V to the actuator on the bench to see if your repair worked.
  #389 (permalink)
Old 06-06-2009, 09:25 PM
EXv10's Avatar
No need to mark anything. The 2 contacts go up and the part # goes down. Just using tin foil crammed into the slot is an easier and more positive method.
  #390 (permalink)
Old 06-06-2009, 09:37 PM
2000 Ford Excursion
The motor definately went in correctly but I may rip into it in the a.m. and make sure the armatures are in the right spot )I was careful with the second one I did). I did the mod after that attempt on the hatch motor and it worked but the linkage wasn't moving enough to actually unlock the latches. The top of the actuator broke off trying to slide it back on the latch, I superglued in back on but the attempts to lock/unlock just broke it again. So off to ebay for one actuator.
__________________
Tags
1995replace, 2000, 2001, actuatorf150, door, f250, f350, ford, lock, locks, power, problem, resistor, thermal, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
