O2 Sensor Problems - 98 Explorer 5.0 V8
I have a 1998 Explorer XLT with the 5.0L V8. My check engine light has been on and off sporadically for the past two months. Lately, it has been on more than off. I brought it to a local place to diagnose the problem. Both upper O2 sensors are shot. They want $340 to replace them.
I called a local parts store and can order them for $59 apiece. The local Ford dealer wants $116.95 per unit.
What kind of difficulty level am I looking at if I tackle this myself? Any advice?
Thanks,
Eric
Thanks,
Eric
It's not likely that both O-2's have gone bad at the same time
Lots of times the O-2's are just messengers for problems elsewhere.
A vacuum leak will cause an O-2 sensor lean code, and replacing the O'2s wont fix a vac leak.
Best bet is to take it to Autozone etc & have them pull the trouble codes which wont cost you anything & then post the codes here.
Thanks,
Eric
Thanks,
Eric
The left side sensor can be replaced in under 15 minutes. It's close to the oil pan and unplugs easily. The right side is a challenge because of its plug location. That plug is basically on top of the tranny. If your arms are the size of Olive Oyl's, you can reach right up there and pull the plug in no time. I had to remove the center console and then the wire was simple to unplug. That console takes a bit of effort to remove. The do-it-yourself price is less than $100.
alot of codes tell you that the o2 sensors are bad. i had a check engine come on in my 97 5.0 that said both o2's are bad, and it ended up being the intake manifold gasket needed to be replaced. before you spend the money on new o2 sensors, post the codes here. its most likely another problem. i'm thinking an air leak somewhere......
btw if you do wanna replace them, do it yourself. they are fairly easy to do.
p.s. and on my 92 4.0 a while back, check engine pointed to a o2 sensor passenger side being out, ended up the IAC needed replacing.....
If the local shop checked the codes and it indicated slow response from both O2 sensors, they may indeed be bad. I would check with the shop to see what codes they came up with, since you already had them check it out and especially if you paid them to diagnose the problem. If your vehicle has over 100,000 miles and they have never been replaced it is not a bad idea to do so as preventative maintenance, and it just might improve gas milage. Make sure when they say "upper" that it is the sensors before the catalytic converter. If you replace them yourself viiidude is right on, you will have to remove the console and go in from the top. Not that big of a deal once you decide to go for it.
Well from what I was told, there are 4 Oxygen sensors and I was told the upper two are bad. I assumed he meant the front since the other two are right before and after the catalyst if I am not mistaken.
They did not give me the codes but I was told the heat sensor in each was bad. I don't know what that means. Anyway, the shop has never wronged me but I don't want to spend that kind of money to fix them. The car will run fine except it will burn a little more fuel. My next inspection is not for 10 months anyway.
The vehicle has 83k on it. I bought it at 54k so I'm sure they're originals. I am going to search the Auto Zone site and see if there are any relatively closeby and I'll get the codes and post them here.
Thanks for the help everyone.
Eric
Eric
Its going to be on the left side of the engine/truck as your facing the front of it, and its going to be pre-cat. So find your cat and work your way towards the engine. It is sitting on top of the exhaust pipe. I don't have my 5.0L anymore for a reference but if I remember correctly, that's where it is.
