Maine lift laws
Maine lift laws
I currently have a 1978 Ford F-250 4x4 extended cab that has a eight inch lift with 38in Super Swamper SSR's and reside in New Mexico. This set up here is completely legal as long as my headlights arn't over 54" and tail lights over 72" from the ground.
Where I am running into a problem is that in July I am moving to Augusta, Maine and want to be able to register my truck there. Is there anything I can do or start doing to keep my truck?
I have searched the internet and am having difficulty finding a concrete answer to my question. All I have is that the original suspension can not be "disconnected" what ever the hell that is suppose to mean. I found that a heavy duty suspension can be bolted on but it does not give a definition of what they mean by "heavy duty". They also state something like that you can only go two sizes larger from the original factory tire spec.
The law in accordance to vehicles in Maine seem to be not real clear. Can someone help me out so I can start getting ready to go. Do I need to reduce my lift? Do I need to reduce my tire size?
ANY help would be appreciated!!!
And by the way FORD RULES!!!!
Quick and easy.. NO...
I just called a buddy that does Maine inspections and on a vehicle between 7500 and 10000 GVW it's 28 inches to front frame from ground and 30 inches to rear frame from ground. He also said he thinks there is a limit on the kit itself being 5 or 6 inches. The heights are right out of the book and he was going by memory on the kit height.
New Hampshire has about the same limits if not exactly the same but goes further to say "no modification what so ever". Figure that one out????....????
And you can also get ganked on a loud exhaust system to, but usually only if it's overly obnoxious.
Hope this will help out! I think I'd say where I was at with those laws!
bpatton74
Mainers tend to keep a low profile.lol. They have been getting pretty strict up here the last couple of years with inspections. A lot of guys used to doctor their trucks to get a sticker,but they go by the original equipment these days. They are fussy about window tint also. I'm not sure what you might have,but they won't go for the stick on type.
On a side note,I can't imagine trying to drive around the Augusta rotarys with your current setup. Good luck with your move.
You can check https://www.ford-trucks.com/lc/lc.ph...StateLaws.html and lookup Maine in the PDF file. I looked NewHampshire and it is TOTALLY WRONG.
In NH Antiques have to go through state inspection every other year.
I'm sure Maine has something similar. I don't think they would let any vehicle on the road without some kind of safety inspection.
And Showgirl... Welcome to the site.
What state are you from? I am guessing Maine.
I double checked the law. There are no inspection requirements whatsoever. There are restrictions that were similar to the restrictions of my collector's insurance. Farm vehicles in Maine have to have only a few things inspected. If anyone else has anything to add, by all means. I got the info from the Maine DMV website and might just give them a buzz!
I live in Maine, yes.
skinnypartdeux
01-03-2017 11:21 AM
ol-blu
10-09-2016 08:10 PM
Nytefog
1999 to 2016 Super Duty
10-06-2016 08:46 AM
Big-old-460
61
09-07-2010 09:49 PM
