Y block with a 15426378 firing order?
I own a 1963 ford F-100 with a Y block engine. The door tag suggests that the engine is a 292. The exhaust has the crossover pipe. The carb. has a C3TF stamp. The engine block has a C2AE stamp and the intake has a COAE-9425-f stamp. The distributor has a B9AF 121? stamp. The firing order is 1-5-4-2-6-3-7-8 Counter clock direction. Is this a 292 y block or maybe a different size engine? I keep reading that the Y block has a 1-5-4-8-6-3-7-2 firing order. Any help would be greatly appreciated.
Thanks!
Thanks!
Thanks!
Thanks!
Mason
Originally Posted by buns
Just wondering, where did you find the "1-5-4-2-6-3-7-8" firing order info?
I don't know if you have the engine running already, etc. But if you are reading firing order from how the wires are connected, are they simply in the wrong order?
Thanks all for your replies. I appreciate the information about this engine and it is obvious (to you guys) that this is a 292 that I have.
The reason I was wondering about the firing order is it isn't stamped on the intake and the engine won't start now. I am sure I have a Y block, but wasn't certain about the size. I did see the other firing order posted as an answer to someone asking about a 312, but they were wrong I believe.
The engine was running pretty good, but the oil pressure is low when it is warmed up and idling (20psi). Since a compression test is relatively easy I performed a compression test first to get an idea of the condition of the engine.
When replacing the plugs and wires I went by the correct firing order for the Y block; CCW 15486372.
The truck wouldn't start. I checked, re-checked, re-re-checked and confirmed the firing order and location of #1 cylinder. Still nothing but backfire. Everything checks to be OK as far as electrical and the distributor hadn't moved.
That is when I thought that maybe the firing order was different or I had a different size engine. Obviously not and not that it mattered anyway.
The truck still wont start. When looking at the distributor cap the #1 plug location is marked at about the 11 o'clock position. #2 is right at the 12 o'clock position. Does this sound right?
I removed the distributor cap and rotated the engine by hand. I stuck my finger into the spark plug hole for the #1 cylinder and noticed that the distributor rotor points at #4 location when the compression forces my finger out. This doesn't sound correct to me or maybe I am doing the test wrong. I am thinking the timing was thrown off when I did the test. Is this possible?
Any further advice will be greatly appreciated!
thanks again!
Terry
thanks again!
Terry
on
Remove and reseat the dizzie for #1. The most you will be off is 1 position.
The thumb test is valid. #1 is straight back on the cap and just slightly to the left of the coil wire. Id call it 11 oclock.
I just learned something new! I just looked at a C0AE intake and there isnt any firing order. Dont know when Ford quit marking them.
