Holley 94's - what's the difference?
I see lots of different subtypes of Holley 94 carbs out there. The one on Elvis is maybe not original because the air horn doesn't fit the oil bath air cleaner well - I have to shim it about 1/16".
Can't read any type on my carb except "Ford". Should this have a 7RT or 8BA or what's the difference or best one for a 239 or 255 flattie?
-Scott
Elvis '53 F100 with Mercury 8CM heads on I don't know what block, but it runs...
-Scott
There are all different types, and the later model 2110's are phsically similar. There should be a cast-in number on the side near the venturi with the throttle diameter (a true 94 is 13/16"). There were variations for different air cleaners, as you've seen.
Here's a good summary (but only of car applications)
8RT-xxxx is the generic part number for anything V8 truck in 48-52. The engine is an 8RT in a truck, an 8BA in a car.
The differences can include a governor, a hand throttle provision, different jetting, different throttle linkage, etc. Different power valve calibrations. If you look closely some of them have the air horn (where the air cleaner attaches) in slightly different places relative to the throttle plates. The later 2110's use a different choke intermediate lever because their air horn is almost 3/4" further forward. The 2110's also have 1-1/16" throttle bores and are therefore almost 15% larger capacity -- a quick hop up bolt-on. (That's what I'm running).
If your engine is truly a Merc, it wouldn't have come with a 94 at all (as far as I know anyway, I'm not a Merc guy). It should have had a "teapot" style carb, a huge affair with the bowls mounted above the throttle plates in a separate assembly. I forget the model designation but there's no mistaking it, and it's a 4-bolt carb. You for sure have a Ford intake if you've got a 94 carb on it without an adapter.
EIP11
02-09-2017 12:01 AM
mlandrum51F1
1947 and Older Ford Trucks
07-09-2016 06:54 PM
elvis64505
02-19-2013 10:54 PM
Narwhal
11-26-2005 08:23 PM
