How often do you change oil?
on my 94 anywhere from 3-4K for oil changes. I have an oil change lifetime agreement so they use generic filters and chevron 10-30.
on my 04 F350 and my sons 04 F150 they have the extended maintenance agreements and oil changes are scheduled every 5000. That is with non synthetics so I d guess somewhere in the 4-4500 range could be OK. Check your book since I am guessing a new vehicle.
Originally Posted by xlt4me
MC 5w20 is excellent oil based on the UOA's posted on BITOG and easily capable of going 5k miles. I've switched to Havoline, for the moly, which is also an excellent oil. I do 6mo oil changes because of the low mileage I currently put on the Ranger.
I guess I am old school or something but my dad told me to do it every 3,000 or 3 months so that is how I do it I dont care if Ford said I could go 10,000 I would still chance it at 3,000 oil and filter is like 10 or 15 bucks for a motorcraft filter and a good brand of oil so why go more miles on oil when it does not cost that much that is my opionion on it better to be safe then sorry later Dustin
it is if you want to start springing leaks and burning oil, which is what will likely happen if synthetic is used in the older engines, because of the thinner nature of synthetics compared to dino.
the misinformation that goes on here is sad. some high solency synthetics will clean well and will reveal pre existing leaks. synthetics are the same thickness of what you call dino oil, it is cold flow whicher is better. they are not thinner. a syntheic oil has no more anti wear protection than a well built dino. syn's are good for long oci's and cold starts other than that they won't help your engine live any longer.
honestly i would run motorcraft 5w20 with MC filter. a very good combo! MC is a synthetic blend and in my opinion is just as good as full syn, for your purpose. now if u were to do some sort of extended drain intervals i would consider a full syn. but MC is like 1.94/qt at wal-mart, good deal & good oil.
edit: actually trop artic syn blend is apparently the exact same as MC, i have personally just made the switch. 1.28/qt at wal-mart right next to the MC!
and yes 5k would be a good drian interval, however as stated above, i personally am a man of tradition and change it every 3k. but i save my oil so im not wasting it anyways. (im in the works of building one of those waste oil heaters!)
good luck!
good luck!
