Adding Cargo Light to F/G Tonneau Cover
Old 12-21-2005, 07:23 PM
Sporty_Ford's Avatar
Sporty_Ford
Sporty_Ford is offline
I want to add a cargo light to the fiberglass tonneau cover on my F150 truck.
I'm somewhat concerned about drilling holes in the cover and also concerned about using self-adhesive tape that won't stick.
Any ideas out there?
Jeff
Old 12-22-2005, 10:36 AM
griz7674's Avatar
griz7674
griz7674 is offline
I installed a tap and go light from Walmart on the underside of mine. I used velcro to hold it on and thus far it has worked exactly as I wanted. Something else I will end up doing once it warms up is to run an accessory outlet back there. Walmart sells a magnetic light that plugs into this. This way I can obtain much more light and stick the light wherever I want it. Just two thoughts for you.
Griz
