6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Motor Trend says it is a V6....
Old 12-16-2005, 09:38 PM
elemint's Avatar
elemint
elemint is offline
Delayed due to Ford's financial constraints, the heavy-duty workhorse truck range is ultimately destined to receive major changes for 2007. This Crew Cab longbed 1-ton version sports a single rear wheel, and looks to offer a slightly larger cab area. Word around the office says this vehicle is being tested with a new, smaller V-6 4.5-liter turbodiesel sourced from International, promising improved fuel economy.
Great news, too bad it is not an I6 though....
Old 12-16-2005, 09:41 PM
MIKE1646's Avatar
MIKE1646
MIKE1646 is offline
I don't think they would do that.
Old 12-16-2005, 10:12 PM
Mark Wenner's Avatar
Mark Wenner
Mark Wenner is offline
There's an article in the latest Truck Trend which suggests that a version of that motor might make it into the F150 or next generation Expedition, but it's all speculation at this point. No surprise that it's a V6 given that it's basically a 6.0 with 2 cylinders lopped off. I suppose it's possible they could offer it in the bigger pickups, too, given that it's already being used in medium-duty trucks, but it would be another engine option, not a replacement for the bigger motor.
Old 12-16-2005, 10:13 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
you are really taking motor trend serious??????????????????????????????????????????? ???????????????????????????????????????? i would not
Old 12-16-2005, 10:23 PM
elemint's Avatar
elemint
elemint is offline
Well, i hope it is true. This big diesel engine game is a joke. Give me a 6 that is reliable over these marketing bogus v8's that are continually be sold as if all the buyers are teens.
Old 12-17-2005, 12:45 AM
NickFordMan's Avatar
NickFordMan
NickFordMan is offline
A diesel burns fuel differently.
The bigger engine's are more capable of moving heavier loads with more ease, and less boost, reducing fuel consumption. Look at the 7.3L...
I know, I know, I shouldn't explain it as simply as that...but you get the idea.
Old 12-17-2005, 04:35 AM
magnum300's Avatar
magnum300
magnum300 is offline
the 6 would work if you had a 10 speed transmission
Old 12-17-2005, 08:35 AM
Mark Wenner
Boy, how spoiled are we?!?! It wasn't that many years ago that 200 hp and 440 ft-lbs would've been class-leading numbers in a diesel pickup! Not everyone's bread-and-butter is heavy towing, I'm sure a lot fleet owners and plenty of others could do just fine with the 6 as an alternative to a bigger diesel. Options! Since when were more choices a bad thing?
Old 12-17-2005, 02:42 PM
Jerme's Avatar
Jerme
Jerme is offline
A diesel v6 would be much better base engine than the gutless 5.4 for the superduty.
Old 12-17-2005, 03:22 PM
ford390gashog
yes but the 5.4 is the most common fleet setup. being that ford sells so many 5.4's i don't think you will see it being replaced any time soon .
Old 12-20-2005, 12:03 AM
lvjunior's Avatar
lvjunior
lvjunior is offline
I am not sure what the prices are like in tulsa but out here ford is not a very good option for fleet vehicles. My company runs a very large fleet and have a mandated 70% alternative fuel requirement, so we are replacing all of our CNG/Gas F-150's for diesels (to run on biodiesel) and ford does not have a base model even close to the prices of gm and dodge. The majority of the large fleet companies seem to be replacing their fleet with the dodge cummins quad cabs. Your guess is as good as mine as to why the shift from ford but I know that the duramax trucks that chevy sold us where stripped compared to the dodges they where bidding against and ford wasn't even close. The Dodges we are running are also getting 15.6mpg city average and the best my 06' ford would do was about 13.4
Old 12-20-2005, 10:24 AM
kw5413's Avatar
kw5413
kw5413 is offline
Back to the Motor Trend article...their authority is "word around the office".
Guess they haven't heard the word around the International office...
Old 12-20-2005, 01:05 PM
BigF350's Avatar
BigF350
BigF350 is offline
Or the Ford office for that matter...
Old 12-23-2005, 09:36 AM
blueeyes2478's Avatar
blueeyes2478
blueeyes2478 is offline
Its all hear say.Try not to listen.
Old 12-23-2005, 10:31 AM
Redneck1016's Avatar
Redneck1016
Redneck1016 is offline
I hope that a 6 cylinder will not be the biggest offered in the heavy duty trucks. If Ford does that I think they have pretty slit there throat. What they need to do is improve on the 7.3. I did however like Jerme's idea. Replacing the 5.4 with a small diesel would be great step forward, not that the 5.4 is a terrible engine, but it sucks because has minimal pulling power and maximum fuel consumption and it really is not worth it. I have 4x4 supercab witha 5.4; I can only imagine what a slug 4x4 crew cab would be with the 5.4.
Quick Reply: Motor Trend says it is a V6....
