Dtc Codes
Old 12-14-2005, 09:06 PM
Z-MAN's Avatar
Z-MAN
Z-MAN is offline
Unhappy Dtc Codes
Does Anyone Know What This Code Means Dtc 9352. I Went Through The Odometer Diagnostic Trick And This Is The Code That Popped Up And Yes Check Engine Light Is On Now. Truck Has Been Running Fine When At Norm. Operating Temp. But Cold Weather Starting Is Very Loud And Knocky And White Smoke For 4-5 Min That Stinks I Fear Its Trouble With Head Gaskets, Head Bolts, Or The Dreaded Egr Valve. Puking Coolant Out Of Cap Not A Tone But About A 12 Ounces A Month
Old 12-14-2005, 11:20 PM
clouden's Avatar
clouden
clouden is offline
What model, engine, year truck do you have?
This is not a valid code in any of my literature.
Are you sure you got all the numbers right?
there is usually a letter first then #'s
Old 12-15-2005, 11:01 PM
shiftkx's Avatar
shiftkx
shiftkx is offline
dude your in a really cold state , your truck should smoke when its really cold for about 15 min or till your truck hits 120º or so. im from cali i never seen my truck smoke till i moved to washington, now it smokes till its warmed up... the res for the coolant will rise above max when the truck hits 196º but lately its been super cold and its near the min in the coolant tank.. inspect your heads and if it doesnt smoke when its all warmed then dont worry bout it..
Old 12-15-2005, 11:08 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
the truck should not blow white smoke. condensation yes but not smoke.
Old 12-15-2005, 11:21 PM
shiftkx's Avatar
shiftkx
shiftkx is offline
my truck will blow clouds of smoke when its about 100º still cold. once it heats up to 140 or higher it doesnt smoke at all.. then again all cars up here smoke like crazy its like 20 degrees out here =(
Old 12-17-2005, 09:43 PM
Z-MAN's Avatar
Z-MAN
Z-MAN is offline
2003 LARIAT FX4 CC/SB W/6.0
R 0402 RL 0402 DTC 9542 NO LETTER BEFORE THIS ONE IT FLASHES DTC AND THEN FLASHES THIS # 9352
Shorty 66
1978 - 1996 Big Bronco
09-08-2013 05:35 PM
the deno
1999 to 2016 Super Duty
06-21-2013 01:53 PM
jonathan642
02-29-2012 02:02 PM
larry1211
Electrical Systems/Wiring
10-16-2007 06:31 AM
PLatreille
1997-2006 Expedition & Navigator
02-13-2005 01:11 PM
Quick Reply: Dtc Codes
