Dtc Codes
Does Anyone Know What This Code Means Dtc 9352. I Went Through The Odometer Diagnostic Trick And This Is The Code That Popped Up And Yes Check Engine Light Is On Now. Truck Has Been Running Fine When At Norm. Operating Temp. But Cold Weather Starting Is Very Loud And Knocky And White Smoke For 4-5 Min That Stinks I Fear Its Trouble With Head Gaskets, Head Bolts, Or The Dreaded Egr Valve. Puking Coolant Out Of Cap Not A Tone But About A 12 Ounces A Month
What model, engine, year truck do you have?
This is not a valid code in any of my literature. Are you sure you got all the numbers right? there is usually a letter first then #'s |
dude your in a really cold state , your truck should smoke when its really cold for about 15 min or till your truck hits 120º or so. im from cali i never seen my truck smoke till i moved to washington, now it smokes till its warmed up... the res for the coolant will rise above max when the truck hits 196º but lately its been super cold and its near the min in the coolant tank.. inspect your heads and if it doesnt smoke when its all warmed then dont worry bout it..
the truck should not blow white smoke. condensation yes but not smoke.
my truck will blow clouds of smoke when its about 100º still cold. once it heats up to 140 or higher it doesnt smoke at all.. then again all cars up here smoke like crazy its like 20 degrees out here =(
This is not a valid code in any of my literature. Are you sure you got all the numbers right? there is usually a letter first then #'s R 0402 RL 0402 DTC 9542 NO LETTER BEFORE THIS ONE IT FLASHES DTC AND THEN FLASHES THIS # 9352 |
