i dont think they can be changed you have to change the whole button i bought mine for $32 for one side from the dealer you can try rockauto.com the sell alot of them dealer only items for cheap prices
no they are not hard too replace diconnect the battery wait a few minutes pop the two plastic covers on each side of the airbag take the two screws or maybe nuts off remove the airbag ( be careful with the airbag ) remove the two screws on the button unplug and reverse to install
yea its safe as long as you wait 5 to 10 minutes after you disconnect the battery before you start working with the airbag because the air bag has a back up battery that last a couple of minutes after power from the main battery and after its out just handle with care always place the black side up when setting it down
