BEWARE: WD-40 is NOT a lubricant
It is by definition a "PENETRANT" and a "SOLVENT"
And where that gets important is on Door and Hood Hinges and bicycle chains...
I put it to you this way -
Someone I read about spent $2,500 dollars on an Italian Bicycle (Campagnolo, I believe) and used WD-40 on the chain...
50 miles later, he noticed a lot of aluminum flakes on the chain....
It had erased the oil that was protecting a $250.oo front gear set, and the chain ate it alive...
WD is a good cleaner, and can free stuck bolt threads by getting the "GUNK" out, but has no lubricational properties at all...
Your best bet on door pins and hood hinges is to use a spray form of white lithium grease, which bubbles into the crevices and has a truck-load of "Staying Power"
~Greywolf sends
~Greywolf sends
on
grey
you are so right...
from how stuff works.com
"WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion-a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try. Please see our history section for more information."
it you want it lubricated use oil, grease, lard, ky-jelly... but don't expect wd-40 to do an adequate job
john
you are so right...
john
I can tell you all this. I work at an environmental drilling and construction company, and at one of the sites i went to, they made wd-40. come to find out the company also makes "NIX" which is used to get rid of lice. i talked to one of the chemist, and he said that it is the same thing as wd-40, but just different ratios of this to that. I don't know about you, but I wont use these items on bolts or my kids hair. I'll break or cut that bolt first, or cut my boys hair all off. As for using it for starting fluid, it does work, but I am not to crazy about that either.
FROM wd40.com
WD-40 Company has been providing the world with top-quality, multi-purpose products for nearly 50 years. With a household name like WD-40, users know they can trust a brand that cleans, penetrates, protects, and lubricates just about anything.
I've said it once or so, one of the best agents
for freeing nuts or threaded things is OIL-OF-WINTERGREEN
I was told when I was younger that OIL-OF-WINTERGREEN
is probably one of the best freeing lube's that is
available,was told by a senior farmer/mech that it will
free up exhaust bolts on a R3350 straight stack engine,
works like crazy.:-)
Greetings All,
I am a cyclist and truck freak.(Go figure) For "Greywolf", Campagnolo is a component builder, such as chain rings and shifters. They don't actaully build bicycles. They are the European equivelant of Shimano. Anyway, spraying WD-40 on a bicycle chain or anything that needs to be kept lubricated in a big no-no. WD-40 is marketed as a penetrant. I've found that it's also a good degreaser and is great for removing decal residue from glass. "WD" means Water Displacing and "40" is the formula number. It was originally developed for use by NASA. They sprayed it on rockets to help prevent corrosion and condensation from forming and freezing at high altitudes. It's other uses were later discovered because employees were taking it home to use as a penetrant. I'm not bashing this product because it is great stuff. But, there are times when it shouldn't be used. P.S.- I lubricate my bicycle chains with the same 80 weight gear oil I use in my truck's tranny and rear end. It works great.
BUBBA
BUBBA
Silicon is a lubricant in it's own right.
And one piece of advice I can give you there - is KEEP THAT STUFF AWAY from paint!
It can soak into the pores of the metal, and make paint forever after "fisheye" on the affected area.
I have heard it can eventually be cleaned off, but why go there to start with...
This makes me wonder if WD-40 can clean silicon out of metals....
