Electric Supercharger
You mean the ones that look like boat engine compartment exhuast fans? Then, no they will not help. Theres no way that plastic propeller will compress any significant amount of air.
Only electric super/turbo charge setup I imagine would work would be to take and actual turbo housing and fan (compressor side) and run it with a fairly powerful electric DC motor capable of spinning it what, 80,000-100,000 rpms? Of course if it was that easy or practical, then it would have been done already
I honestly wouldn't bother...
They don't compress the air (which is what you need for additional power) - and they just add more load to your electrical system.
Then you would have a centrifugal supercharger...
Originally Posted by greenacrescanoe
These things are a joke, but try it anyways I'm curious what it will do
Big350, didn't know that
You'd be $$$ ahead just buying the turbo whistle to stick in your pipe. Both are a waste of money, but the whistle is only $20 and at least it will sound like theres a turbo under there
http://www.turbomagazine.com/tech/0406tur_knight/
How are these electric superchargers? They seem to be the only ones that would possibly work.
UUranium
HAHA. I wish that i could afford that (not trying to insult you). I'm a student in college just like you who wishes he could afford all the toys but I need to buy a tuba first (music education major).
Everyone was always bashing those things on ebay (which I can't blame them) that I wasn't sure if the Thomas Knight superchargers actually worked, hence why I threw that idea out there. I guess they do.
If i could try anything out experimenting it would be adapting one of those Cat-Back turbo systems to the V10.
i have always been skeptical about those catback systems. i understand that running the cats at a hotter temp allows for them to eliminate more emissions but i doubt that many people would be worried about epa ratings when they are puttin on a turbo. if you stop and think about it the more room you have in your exhaust before the turbo the longer it takes for the turbo to spool. if it was me, and yes i am thinking of doing a tt 6.8l V10, i would just run the turbos up to the front and leave it at that. not to mention what happens if something were to give your turbo a good whack from underneath. good luck with school.
UUranium
UUranium
See I figured that even though the gasses won't be as hot as they are near the turbo, it has to also be the velocity of the gasses that drives the turbine. I figure the velocity of the gasses might be greater as they travel back, which is why the STS product has gotten such good "testimonials" (if they are true testimonials). You could protect the turbo if needed but the one thing I still don't like about their system is the air filter being exposed like that. I would personally re-route it.
the more heat the more velocity. also the less area you have to fill the less time it takes to pressurize and that is gonna lower your velocity also. the exhaust system on a turbo can be one of those critical make it or break it points and i just don't see how putting that much distance between turbo and engine is ever gonna help anything except for lowering the egt's some. while it might sound good on paper(doesn't really sound good to me at all) it would probably be a turd in real life when compared to a turbo setup where the turbo is in the engine bay(or at least closer). when the pro 5.0 guys start mounting their turbos like that then i will believe that it actually works better, but until then i am gonna stick that turbo in front and get blown
To use the very basic Bernoullis principle (this doesn't take into account thermal energy), the turbo's output is proportional to:
Exhaust gas pressure prior to the turbo
The square of the exhaust gas velocity (i.e. double the speed, 4 times the output).
Having a turbo mounted further away from the exhaust manifold only reduces both of these (as well as the thermal energy I didn't take into account).
You do have less heat soak - but this can be overcome very easily with an appropriate sized intercooler or water injection.
