AC Compressor kicks in to often, Gurgling sounds
So, with regards to my previous post https://www.ford-trucks.com/forums/s...d.php?t=418547
and trying to find whatever was causing my sound. Iv done some digging.
Sitting in trafic, with the break depreased just enough so I would not move forward, sudenly the RPM's increase slightly and I lurch forward, this happend the same time the sound of gurgling happens. I then thought the AC was kicking in. When I got home, I checked, and sure enough, thats exactly what was happening.
When I have the climate setting in heater, the AC compressor kicks in, what I find odd is.. it kicks in for about 1.5 seconds, off for 6 seconds, then back on for 1.5 seconds, (aprox) and repeats.... i dont understand why it would kick in for such a short time, and how this would cause gurgling inside, almost as if a buble in a water line, but the AC is compressed gass, is it not?
Somone enlighten me!
Stopped by the Ford dealership on my way home, they wanted $120+ to recharge the system, and brought up a good point, Freon just dosnt disapear, so I could be searching for a leak. If I recal, you cant purchase Freon in Canada unless you have a ticket, or whatever. I know a few guys at work that should be able to help me out who work in the industry. Im going to see if I can get it topped off soon befor I blow the clutch, I will keep everyone posted.
Mine does same thing. Mechanic friend of mine said that the gurgling noise was the heater core, but the ac kicking on/off was probably due to low freon. Also, when the ac is on the motor idles higher due to the extra load that it puts on it(thus the surge forward). I unplugged the compressor for now, since it is getting cold(no need for ac).
Originally Posted by Forddieselweasel
on some cars dont they have the ac compressor pump come on some times when the heats on (winter) to keep everything "lubbed" and in working order?
Check your owner's manual, it's described there.
Steve
I have seen this on a few motors, idle would fluctuate while at the same time the a/c compressor would cycle on and off. I too though low on R-134a but it turned out to be a sticking throttle valve which is eletronically controlled. Removed the intake and cleaned the throttle valve and the problem when away.
This is quick enough to do that if its not the problem you have'nt wasted too much time.
