Impetus to change my plugs
Okay...get a good glass of your favorite beverage - brave juice is good.
While you're sipping your intestinal fortifier, scan the engine compartment. You will notice that the engine is huge, almost monstrous, but don’t let it intimidate you. You are the master of this beast. Take another sip. Fire off the air compressor and let it cycle off. Get your metallic soldiers in their strategic locations – you know the ones that will do the best job. To them you are a god; their supreme general. Take another sip. Once again scan the battlefield and note those obvious obstacles that you will have to overcome. Soon it becomes evident that the enemy is not that dangerous; the task not that daunting. You have walked many a weary captain through it on many occasions. Think of each plug as a little Sadam – subdued – in its own little spider-hole. Take another sip, grit your teeth, and yell, “ARGH!!” (it helps)
Now lay your torso across that engine. Notice that it now appears so small and restrained…almost inviting. It is then that you realize that you have performed this task many times over in your head and you find that your actions are automatic. Before you know it you’ve completed what was once considered arduous and fretful…and you’re anticipating how much faster the rubber will burn from the rear tires.
Originally Posted by vtmdsm25
Don't forget to check your boots ...
Seriously, I have 10 brand new ones...
I might take that suggestion of doing #5 and #10 first...
Although I planned on taking everything apart all at once, marking each coil with cyl #, and taking pictures as I go along...
Originally Posted by krewat
OK, guys, I need help... seriously...
I need the gumption to change my plugs...
YOUR A BIG CHICKEN!
YOU DON"T KNOW HOW TO DO IT,DO YOU
CHICKEN! CHICKEN!
I'm calling you a chicken!
Now get your **** out there and change them!
Me thinks he might be a little mad at me now, so what he's a chicken
MR Big ,don't be so easy on him! sip a little favorite bev...LOL
All in fun Art !
One of those topsider things makes it alot easier.
Rich
