Tailgate locks frequently!
I have an 02 FX4 that was bought used therefore have no owners manual. This may be stupid but my tailgate locks frequently on its own! I have found no pattern as to why or when it does it. It will simply lock occasionaly whenever. Maybe I am doing something I do not know that triggers it but it is really annoying! Anyone out there help me out...I'd appreciate it!
Ford Special Service Message 16835 says.....
1997-2003 F-150, 2001-2003 EXPLORER SPORT TRAC, AND 1999-2003 F SERIES SUPER DUTY - UNCOMMANDED LOCKING TAILGATE
SOME 1997-2003 F-150, 2001-2003 EXPLORER SPORT TRAC, AND 1999-2003 F SERIES SUPER DUTY EQUIPPED WITH A LOCKING TAILGATE MAY EXHIBIT THE TAILGATE LOCKING BY ITSELF WHEN SLAMMED SHUT OR WHEN THE VEHICLE IS BEING DRIVEN OVER ROUGH ROADS. THIS MAY BE CAUSED BY THE ASSEMBLY PROCEDURE USED TO INSTALL THE TAILGATE RELEASE HANDLE (TAILGATE LATCH REMOTE CONTROL) TO THE TAILGATE. TO SERVICE, REMOVE THE HANDLE PER THE F-150 WORKSHOP MANUAL, SECTION 501-14 (HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS). DO NOT REPLACE THE HANDLE ASSEMBLY. REINSTALL THE REMOVED ASSEMBLY AND REASSEMBLE TO THE TAILGATE PER THE WORKSHOP MANUAL INSTALLATION PROCEDURE. MAKE SURE THAT THE LOCK IS IN THE UNLOCKED POSITION WHEN REASSEMBLING. THIS STEP IS VERY CRITICAL TO INSURE THAT SAME SYMPTOM DOES NOT RE-OCCUR.
I'm a tech at a dealer so I have access to info like that.
You probably wont need a manual to do the repair. You need to remove the cover over the linkage on the back of the tailgate and then you can see the lock etc.
The important part is to make sure the lock is unlocked when reassembling.
Here is the first place I found with them. But they are not the only ones.
http://www.slickcar.com/productdetai...ProductID=2425
Do a search on the net for POWER TAILGATE LOCK FORD and you will find other places that sell them too.
