1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Hole in cylinder head - ouch!
Old 10-29-2005, 06:16 PM
rocketman442's Avatar
rocketman442
rocketman442 is offline
I have a '99 F-250 Super Duty (5.4L) with 263,000 miles on it. It developed a pinhole in the LS cylinder head right below the thermostat housing, causing a coolant leak. After sticking it with a screwdriver, I ended up with a 1/2" hole!! Has anyone ever encountered this? I can't even drill & tap it as it is near the top of the head where there is a bend in the casting. I really don't want to pull the head off - is there some "super epoxy that will stand up to the coolant temperature/pressure? Thanks.
Old 10-29-2005, 06:55 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Maybe get someone to Tig weld a patch on it.
I would say it was corrosion from not changing coolant ???????????
A 1/2 inch hole is to big for jb -weld
Don't forget if you have someone weld it to disconnect the battery and isolate the pcm grounds also or you will blow up the pcm.
Rich
Old 10-29-2005, 07:22 PM
bigsbetter's Avatar
bigsbetter
bigsbetter is offline
I'll have to agree with Fortyfords. It sounds like your coolant became acidic.
Old 11-02-2005, 10:07 PM
rocketman442
OK - I went the JB Weld route. I hammered out a 1/16" piece of aluminum to fit the corners and to cover the hole by 1/2" on all sides. I sanded the area and wiped it down with acetone, then JB'd the whole thing. If this doesn't work, then I might use an expanding rubber plug. I'm afraid of what the heat might do to the head if I have it tig'd, given the thin wall thickness. I'll know by tomorrow!!
Old 11-03-2005, 06:16 AM
dew487's Avatar
dew487
dew487 is offline
For what it's worth, I have had good luck using JB weld on my 1941 Ford 9N tractor. My cylinder block developed a 1/2" crack at the water jacket. I ground v-groove at the crack and applied JB weld. It's held up for 3 years now... Hope it works for you.
Old 11-06-2005, 08:24 PM
rocketman442
All is well with the repair. I have about 50 miles on it with no signs of leakage. While I had the opportunity, I replaced the thermostat (original!!), o-ring, tensioner bearing (got it at Grainger for $6.76), belt & coolant. My owner's manual says "if it has orange coolant, use the long-life stuff; if it has green coolant, use the regular stuff" (not verbatim). I asked my local dealer and they said the same thing. GAR! Being that my coolant was orangish-green, I flushed the whole thing and put in the green stuff. I'm keeping my fingers crossed!!
Old 11-06-2005, 10:09 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I heard about this as a known issue... coolant flow past that point erodes the metal, and it leaks.
I have NO idea if there is a fix or updated head, I only know what I've read on this site
art k.
Old 11-18-2005, 03:11 PM
texcan's Avatar
texcan
texcan is offline
How is your repair holding up? Interested in knowing!
Old 11-18-2005, 06:51 PM
bear1911's Avatar
bear1911
bear1911 is offline
I had this happen on my 99 V10. Ford repaired using a sleeve and epoxy in the coolent passage. There were casting issues on the heads.
Old 11-18-2005, 07:24 PM
rocketman442
So far, so good! I put around 300 miles on it with some heavy hauling and no leaks!! I went bananas preparing the surface, which I guess paid off. I have some pictures of it and I'll have them up here as soon as I remember how to do it! A while ago, I repaired a broken 442 emblem stud with JB Weld (then threaded it with the speed nut!) and have sworn by it ever since. It has a working temperature of 600 degrees F, so 200 degrees F is a walk in the park.
Bear1911 - Is the sleeve to which you are referring a V10-specific item? Would one be able to get this right from Ford parts?
Brad
Old 11-18-2005, 07:34 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
You can never prepare the surface too much - unless, of course, you break through to the other side
Old 11-18-2005, 09:37 PM
bear1911's Avatar
bear1911
bear1911 is offline
Brad
I don't know if it is specific to the V10, the shop manager said this was a known issue with the heads, so my guess is that it could have affected the v8 also. It was warranty work. I do not have a part number.
Old 11-20-2005, 07:30 PM
rocketman442
Here are the pics. Unfortunately, I took the picture of the actual hole with my phone.
http://img26.imageshack.us/img26/5316/dsc015443vn.jpg
http://img504.imageshack.us/img504/1544/dsc015461kq.jpg
http://img469.imageshack.us/img469/4538/dsc014091rg.jpg
http://img469.imageshack.us/img469/259/dsc013951hb.jpg
Images changed to links (it's a little nicer for the dial-up users. -Beast12
Old 10-05-2008, 03:13 PM
rocketman442
Hole in cylinder head update
Well, it's been almost 3 years and 13,000 miles since fixing my cylinder head with J-B Weld and it's holding up great! This stuff is unbelievable!!
Old 10-05-2008, 03:36 PM
tac53parsons's Avatar
tac53parsons
tac53parsons is offline
Thats crazy!!! My truck has 130,000 on it. I hope mine lasts as long as yours. What kind of repairs have you had to do? Transmission?
Quick Reply: Hole in cylinder head - ouch!
