I need experienced advice on the mods I chose
I have a 2002 F-150 Supercrew with a 4.6L. I have no clue what gears are in it but it was a dog off the line to start with but once it got moving it was fine. I ended up lifting the thing 7.5" and slapped 35" tires on it and believe it or not the performance didn't drop as much as I expected it to. I recently threw on the AirAid intake kit and PowerAid spacer and purchased the Hypertech Power Programmer III and I am NOT impressed with the output that I've noticed, or should I say haven't noticed. Right now my truck seems to "load up" off the line and then gets going. What could be the problem there? Is it trying to swallow too much air? Another thing is, I know I need to put new gears in it but I am trying to figure out if 4:11 or 4:56's are my best bet. Please help me with that mod. The other help that I need is: Did I purchase the right programmer? I wanted the try the Diablo Predator but no one I knew had any knowledge of their performance. Doesn't the Predator offer more options than the others and if so, is it worth it? Any advice or input would be invaluable.
Since I'm new at all this mod stuff, what do you think of the truck "loading up" when I accelerate off the live? It's almost like I am drowning it with air and as soon as it catches its breath it moves. Would this have to do with the new air/fuel mixture from the programmer or the new intake system? I do have the luxury of returning the stuff I just bought but I need to do it quick if I do.
Originally Posted by code_red
How many miles does the truck have on it?
Since I bought it I've put a 7.5" lift and 35" tires on it and will be putting 4:56 gears in it to get it back to where she should be.
Sounds like the maf sensor is dirty and not measuring the airflow properly, I'm not an expert by no means but it did help my truck out a little, do a search on it in the forum and you will get all the info you need to do it yourself. Might want to do a seafoam treatment for your intake and combustion chambers, pick up a can at your local Napa and just follow the instructions.
If that doesnt do anything for ya I wont think the added diameter of the tires you put on basically turned your axle into a higher ratio hence the loss of power from start-up. The 4:56's would drastically improve pick-up from a dead stop and you would be surprised your gas mileage doesnt change a whole lot.
I've cleaned my MAS with brake cleaner and that helped a smidge but the truck still wouldn't get out of its own way. What is the seafoam treatment? Is it actually called seafoam treatment?
I wouldn't think its swallowing too much air. That can happen in a carbed engine, but in a fuel injected motor, as long as the engine has an accurate read of how much air is coming in, it can correctly compensate. That's why you don't want to "over-carb" an engine, like putting a 1000cfm carb on a puny carbed v6, it'll drown it. Not so with fuel injection. It sounds like its not being metered, except it only happens off the line. thats kinda weird. I have almost the same mods as you with an 01 5.4 - k&n 77series intake, bbk 75mm throttle body, glasspacked exhaust, throttle body spacer, and my truck visibly raises the driver side up when you mash the gas at a stop, its got no problem off the line.
