1940 FORD 3/4 Ton Stake
I have a 1940 Ford 3/4 Ton Stake Bed with the Original 16 " Wheels ( Bolt Pattern like a V W ) with Hub Caps. This Truck is similar to the 1 1/2 Ton except shorter Bed & the 16 " Wheels.
I would like to put different Wheels on.
Does anyone know of a Wheel Company that may make Adapters or Wheels for that Bolt Configuration???
http://autohobbypage.com/cgi-bin/_tr...spf/nat330.jpg This link if it works is supposedly of a 1940 1 1/2 ton, according to the site. I've been told it is more likely a 3/4 ton. The guy must have changed axles to be able to use the wheels that are shown.
Congrats on your truck. I think they are even nicer than the 1940 1/2 tons.
THANK YOU guys for the Reply........
Here is the Wheel I have that I would like Adapters for or Wheels to Replace same Bolt Pattern,
https://www.ford-trucks.com/user_gal...=93394&width=0 or https://www.ford-trucks.com/user_gal.../93394.520.390
If that doesn't work, my Truck is in the Gallery under MO 40 FORD......
Thanks Again
Thanks Again
THANKS Again for the Replies..........
I have owned this truck for over 35 years and have been told that I would have to change Front Spindles or Axle & Rear End or Axles to get different wheels.....Everything is ORIGINAL except Engine, Trans & Voltage........
I have a few friends in Dirt Racing & will check further........
THANKS Again
THANKS Again
