new process 435 rebuild?
It's been a long time since Ive posted but it's good to be back!!
So the delema goes like this. I have a bunch of roller bearings and a clip in the bottom of my transmission. Found them as I was reinstalling my transfer case I just got back from the shop. just as I was about to hand the T-case I noticed The output shaft that merries the tcase to the tranny was verry sloppy and the rear seal had come out of the tranny case towards the rear. Up top I tried to troubleshoot and found the shifter lever was bound. I popped the top off the tranny and noticed the nylon insert on one of the forks was missing. So with a fondness for 90 weight hand soaks, I went a searching where I felt the beginings of a nasty job. A pile of roller bearings 1/2" by 1/4" a clip, a nylon bushing and another roller bearing race with all of its bearings. The question goes some thing like "hmmm, wonder where these went???" Any tips on where to find a exploded view of the np 435 or a rebuild manual?? say some thing step by step. All these gears and bearing's are causing me a fit.
Thanks for the help!
STU
i just about got into a rebuild of my np435 but had to put it back together quick because my car's tranmission's about to go out. anyway, in some searching i did, i came across some usefull information:
if you want good hardcopy of an exploded view, you might want to check your local tranmission shop. they made a photocopy for me from a binder they keep that has exploded views of all sorts of tranmissions. i also got parts through them for somewhat decent prices. another source is "http://www.angelfire.com/wi/mikeswwwsite/images/tranny11.jpg" (this site's odd html scheme couldn't deal with the link to the image), a scan of an exploded view from a ford dealer repair book. and if you're looking for more information about the np435, the guy that i linked to above details the [a href=http://www.angelfire.com/wi/mikeswwwsite/tranny.html]process[/a] he used to put the np435 into his jeep.
hope this information helps.
