In most cases (EFI) while it is running, pull off the vacuum line to it, the pressure should rise and no fuel should come from the vacuum port. If there is fuel in the vacuum port, the diaphram has ruptured.
I can't seem to find the vacuum port. I see the FPS sitting on the fuel rail, and there a little coneector on top of it, but it seems electrical. Is this it?
