1990 f150 1/2 ton?
Yes. F150 = "half ton". I put the "half ton" in quotes because that's just a throwback name that now has little to do with the capacity of the truck. My reg cab longbed 1990 F150 has a payload of about 1500 lbs. I suppose if you throw 3 average adults on the bench seat at 150 lbs each, the payload would be around a half ton. My F250 (ext cab, longbed) has a payload of ~2800 lbs, don't know how that qualifies as "3/4-ton".
Jason
Jason
I'm looking at buy this truck.
Thanks, I had a question about the locking hubs. If I'm going to town do I have to check to see if the hubs are unlocked. I have to younger kids that get into everything Why would you use "N" on the transfer case for? Do you use 2 high to go to town in the summer? Do you use 4 high on the road in the winter, how much more would it cost for gas?
Push the transfer case lever all the way to the front of the vehicle and the "4x4" lights should go out. Then you are in 2wd. MAKE SURE YOUR HUBS ARE UNLOCKED! The gas milage suffers a bit to have moving parts that aren't supposed to move. (i.e - axle's, hubs, blah)
Mike 4wd's don't get good gas milage but when its snowing out and everyone else is sitting at home or in the ditch that's why I love my 4wd.
I use "N" on the transfer case of my BII or Ranger when towing it behind my RV.
You use 2 High whenever you do not need the extra power and the roads are dry and 4W is not needed.
You can use 4 High on winter roads as long as the snow is not to deep, if it were deep you would use 4 Low.
The cost of gas varies but usually goes up from year to year.
The MPG depends on the engine size, transmission and the read end gear ratio in the truck and also how it is driven.
demotrucker
08-30-2013 06:32 AM
jdhudall
1947 and Older Ford Trucks
20
03-21-2010 10:08 PM
baitbucket
03-20-2007 07:54 PM
