Turn Signals Blinking Too Fast
Hi 'cropharvester' thanks for the reply. Any chance you could list the specs of the electronic flasher? Reason being, the specs on the flasher I installed are: 20A, 2-terminal, 1-10 Lamp Load, 12V, electronic flasher and the problem did not go away. BUT when I take the bulbs out of my truck, the trailer blinks normally. I expected the new flasher to solve the problem but it did not.
If your signals blinking too fast, you gonna need drain the signal line and add Prestone Heavy Duty Signal Fluid.
Just kidding. HaHa. When I got my '94 F150 13 years ago, it does that, look under the steering wheel dash, there a fuse box, I believe it's big round fuse, You gonna need get different one that can handle trailer wiring. I replace it and my signals blink normal when hooked on trailer wires. Sorry I can't remember the name of it but I remember it was big round fuse in fuse box.
Follow-up
Hey Folks,
Thanks for the ideas, so here is some more information:
1. I replaced the existing flasher with an HD flasher, this did not do the trick.
2. When I removed the truck signal bulbs the trailer lights blink at normal speed - I ended up doing this to get the trailer inspected.
3. I checked the trailer and truck bulbs are the same, non-LED bulbs. I replaced them all for good measure but they still blink fast.
Now that the trailer has passed inspection I am not as panicked about this problem but it would be nice if the the lights blinked at normal speed with the trailer hooked up. I suppose I could install a separate flasher, split the wiring between the two flashers, and wire the trailer feed to the new flasher if I was so inclined. But for that trouble I will probably just let it blink fast.
If you have any additional ideas I would be happy to hear them.
Thanks!
Thanks!
follow-up
Hi CS,
Thanks for your help here. I did find a variable flasher online, produced by Grote. I gave their applications engineer a call - he recommended I try changing to LED lights on the trailer & truck in order to reduce the amount of amps running through the flasher, with the idea being that the reduced current draw would return the flasher back to 'normal' speed while double loaded.
I am not sure when/if I will get around to this - I want the blinkers running at normal speed but at least they will still serve the function of a turn signal even though they are running fast with the trailer. I would hate to convert to LEDs without knowing for sure that they will solve the problem.
dadriva
1999 to 2016 Super Duty
18
02-14-2017 09:21 AM
snagmaster86
09-13-2006 07:28 AM
