How long does the 4.6 live?
Nobody can say for sure, particularly without knowing this motor's complete history, but I would expect 200,000 to 250,000 miles is a good bet. 300,000 is quite likely if you're willing to do a valve job. As others have said, something else will usually go first and make the vehicle not worth the cost of repair.
4.6 never dies
Believe it or not, but we were told about a guy who bought a 1997 F-150 4.6L brand new, and drove it every day working for an oil company. He did lots of highway miles and serviced it regularly. When it started getting high mileage, he decided to keep it and see how long it would last. Well, the truck ended up with 728,000 kms or 452,000 miles and it finally was so wore that it would not start anymore - no compression left. Needless to say, the last few thousand miles it was tired and ready to die.
There were some early F250's in F150 clothing. They later changed them to the 7700 package. They had 7 lug wheels and a heavier suspension.
I have seen several Lincoln Mark VIII's with the 4.6L DOHC engines will over 190,000 miles on them and still run really strong.
With proper maintenance, they can easily go 200,000 to 300,000 miles.
We have 197,000 miles on our 98 F150. Runs really good. Changed the oil every 3,000. Used Castrol 10W30 w/ a Fram filter. Just cleaned out the EGR valve and air intake plugged up with carbon. Runs better now. Only had one side catalytic converter replaced. All in all, this truck should get 300,000 before seriously considering scraping it.
Good Truck
I have 165,983 miles on my 97 4.6 F150 Lariat. I have not done any modifications or aftermarket mods to the engine or exhaust and the only thing I have done is regular maintenance and replaced a powersteering hose and the U-joints 1 time..
I have been more than happy with the truck. The only complaint is the lack of horsepower which I do not mind since I get decent gas mileage for a truck. I have been contemplating adding a K&N FIPK intake kit which has been in the back of my mind the last few years.. Other than that I have nothing but praise for the truck itself and the 4.6 and the longevity of the truck and motor itself..
our 98 expy has 142k. Oil changes every 3-3500k. Now burns about a quart every 1500 miles. I changed plugs at 100k, IAC at about 90k. Drain tranny and converter every 30k. I did change the filter at 120k, but it looked brand new. The pan did have some tranny crud in it, the magnet grabbed it.
I agree, the tranny should go first. I'll do one tranny re-build. I expect at least 250k out of the engine
No other mechanicals....some audio issues.
