How to identify old Ford transmissions?
Does anybody have a link to casting #s or other information for old Ford transmissions?
I have three that I'm trying to identify. The first, I believe is the same 3sp that is in my truck now. A stock 3sp unit. The second, is a 3sp OD with a 12v solonoid on the side. I would like to know what this unit came out of originally.
The 3rd, which I have no idea, has a casting mark of "5 1A-100G-A" on the side with a "3100" on the other side. It is almost as long as the OD unit. These buggers are really tough to decode!!
I could post some picts if there are any Transmission Jedis out there. I poked around the tranny forum, but that group doesn't really get into the earlier stuff like this.
Thanks in advance,
-- Jack
Thanks in advance,
-- Jack
Thanks in advance,
-- Jack
Thanks in advance,
-- Jack
I couldn't find anything on the third unit given the numbers you posted. Is there anything else on the transmission case? Could it be an overdrive unit and not a transmission?
same problem here I got a an auto casting mark C9ZP 7006A 2 please help on what it was from and what it is.trying to sell
Usually you can tell what type they are by looking at the pan (on older ones). The shape and number of bolts usully will give it away. Go look at the pans, then go online to someone who sells the gaskets and it will give you an idea.
Some of the series ones use the same pan though. I know the A4LD/4R44E/5R55E use the same pan. Those are the little ones.
This site came from the 47 and older forum reference thread: www.mrgasket.com/ftp/pdf/TrannyID.pdf .
