Seat for an F-1
#31
Celebration?
Originally Posted by Scott123
Oh yeah, I forgot about the dimentions on that thing I promised how long ago? Actually, if all goes well, this weekend I plan on having a "truck assembly party", putting the body back on the chassis and getting the seats in permanently. If you can wait til then on the measurments 49Willard, I'll get them hopefully by Monday.
#32
I am SOOOO very celebrating. Sent you a pm also, but will add here too. We got the whole body onto the chassis and dang it looks like a truck again!!! I took Friday off work to assemble the bed wood, front clip, door hinges, etc, and finally turned the shop lights out at 3 A.M. Saturday morning. Back at it again at 7:30 A.M. to get everything ready for my helpers who arrived at 10. It was a one man episode of Overhaulin' that's for sure. Needless to say, after that marathon session I crashed most of the day sunday and didn't get the seats in. I will tonight though, and post measurements first thing in the morning. I'm going to do a separate post in a few days after the film gets developed to show my progress pics.
Scott
Scott
#33
#35
Ok, I have some measurments and a picture of the seat installed too. I just realized that I forgot to measure the depth of the bracket front to back, but the top frame is the width of the mounting points on the seats front to back, and the bottom frame is bolted directly to the stock cage nuts the original seat was, so you can probably get that measurement on your rig or I can get it again tonight (I could have sworn I measured everything!). Anyway, here's the diagram:
And here it is with the seat installed:
Let me know if this helps or if it causes more confusion - I'm good at the confusing part.
#37
#39
#41
I forgot to mention too that the seat bottom itself has some tilt back in it as well. Even though the frame is around a 4 degree tilt, putting my gauge on the seat it is close to 12 degrees (including the 4 from the frame). I don't know if it's just been so long that I'm so happy to be sitting in it or what, but it actually feels perfect for my build, 5' 10". And with the less cushion in the back, along with the fuel tank moved under the frame, I can put the seat further back and there's actually leg room in the cab now.
One other thing, the front side to side bar on the upper frame is not butted flat up against the side pieces, it's actually twisted some, with the side bars notched to accept it at a different angle. That was done because the front mounts for these particular seats are at a different angle--just in case anyone tries to weld it all together first only to discover that.
#42
#43
51 has that crown too and I left that out of the description, sorry bout that. I laid the front bar across the crown, and cut some extra square tube to fit right where the bolt holes are. It is sort of a spacer, and rather than leave the bottom end with sharp edges, I welded a fill piece of 16 gauge sheet steel there, and drilled the hole for the bolt through it too. The square tube just lightly rests on the middle of the crown, it's main support is through these two spacers. Terrible picture blown up but this is where they are:
Scott
Scott
#44
I made my frame very much like Scott. The only difference is that I did not weld in a lower front bar. Instead to catch the factory seat bolt holes (I used all of the original locations), I welded "L" clips to the sides of the lower fore and aft runners. So I have the runners fore and aft, short uprights like scott and the upper rectangle that the seat frame bolts to. One of these days I will get a digital camera and post pix. Thanks for the idea Scott.
#45
