Not a problem.remove drive shaft,remove yoke, clean area thoroughly,seal should be easy to remove. Ihave used an old screwdriver and a hammer,bending the old seal away from the housing and pry it out. I use a big socket with the same O.D. as the seal for reinstalling in housing.make sure it is CLEAN CLEAN CLEAN!!!
tellico,
thanks man i needed the reassurance that the pinon wasent going to fall into the diff i'll try it on mondayand let ya know how it goes again thanks a million
Louis
