434/ 400 stroker update
Currently we are waiting for an intake manifold.
Here are some specs for your Desk top Dyno people.
Cam is a Hyd. Roller:
Intake Exhaust
Valve Lift .579" .591"
Lobe lift .341 .348
Duration @ .050 216 224
Valve Timing Open Closes
Int. 0 BTDC 36 ABDC
Ex. 40 BBDC 4 ATDC
Lobe Seperation 108
http://www.tmeyerinc.com/351Caluminumheads.htm
The above link has the head flow numbers, we did a little unshrouding of the intake so our low lifts should be better.
4.030" bore / 4.250" stroke
Lets see what you guys get.
Intake Exhaust
Lobe lift .341 .348
Int. 0 BTDC 36 ABDC
Ex. 40 BBDC 4 ATDC
Lobe Seperation 108
OK, this is what I came up with using DynoSim. It has a few more tools than DD2K.
The head flow that I used is what Tim published on his website for the CHI-3V heads. I know that he did some valve work on those heads, so the results could be better than what I simulate. Also the ramp rate on the cam is in question, but I used what DynoSim gave me.
The Torque @ 2000 RPM is 435 ft-lbs, and it peaks @ 495 ft-lbs @ 4000 RPM. The Peak Horsepower is 426@5000 RPM.
I know that these figures can be a lot higher with better head flow at low lift, and/or faster cam ramp rates.
If I use the CHI published head flow, I get:
Torque=429@2000 RPM and 532@4500 RPM, HP=513@5500 RPM.
Both simulations were with a single plane intake and a 750CFM carb. A Dual Plane intake will boost the Torque at 2000 RPM quite a bit.
Try that with an 850cfm carb. When we talked to Demon about my 408ci combo, they told us to use an 850. So, we had a 850 Street Demon built for it.
--J
With a 850 CFM carb, I get 439 ft-lbs torque@2000 RPM, and peak 495 ft-lbs torque@4000 RPM. The peak HP is 450@5500 RPM.
I am having a problem reproducing the previous numbers. Something else must have changed in the file. I will check later.
That cam is not that radical. If I were looking for big HP, then a bigger cam would help. As it is it will be a good low and mid range motor, especially with a dual plane intake.
Well guys here's the best I have so far. We are waiting for the intake manifold to arrive. I did not have another order for CHI, so I had to wait for it to be shipped with someone else's order. Sounds like it will be shipped Mon or Tue.
Next problem is we are closing the machine shop (temp.) for a few weeks. As some of you may know, we had a fire a few months ago. The roof comes off Mon. So I will be spending the time cleaning and answering the phone.
I will keep everyone up the best I can.
