Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-05-2005, 08:17 AM
460f250's Avatar
460f250 460f250 is offline
Garage is empty, add now
460f250 is starting off with a positive reputation.
Bad gas
This may not be the most appropriate forum to post this but may have the most knowledgable people on the topic.
I recently bought a '75 F350 that had been sitting for a number of years. Who's to say how long the gas has been in in the tanks. I added some treatment, methyl hydrate and stabilizer, to the tank along with some fresh gas before I tried to fire it but I fear it may be too far gone. Is there another additive or solution I can add to the tank that will allow me to get it going?
I understand the best method is to drain the tank, and I will try to syphon out as much bad gas as I can first, but I can't really see how to drain it without taking it out.
Any suggestions you could provide would be great, cuz like I said this is probably the most knowledgable forum.....
__________________
Dwayne
'79 4x4 F250 Lariat
Member Alberta / British Columbia Chapter
  #2 (permalink)
Old 10-05-2005, 09:31 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
get as much out as you can, then add fresh fuel and for the most part it should be fine. Big concern will be if it rusted the inside of the tank or not. I have seen some get so bad that the brass float was all eaten away. You can run it short term with rust in the tank, but you will be plugging the filter fairly quickly. Easy way to see it is to drain some fuel after it is run a little, and if it appears kinda orange, you have rust bad.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 10-05-2005, 02:14 PM
460f250's Avatar
Thanks. I think I'll put in a second fuel filter to catch any excess material. I'll also see if I can syphon it down and top it up with fresh gas as well. I was hoping there was some magic elixer that would renew it.
Have a good one,
__________________
Dwayne
'79 4x4 F250 Lariat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
