Electrical outlet (plug in) under the hood.. What is it?
It is an ol' school power inverter. I have read about some folks who have used high amperage alternators (160 A) along with this inverter to run an arc welder. Or you can go with Julie's recommendation for the battery charger...:~) Kinda reminds me of the woman who said that the light on her vacuum cleaner was there so that she could see where she was vacuuming in case the power went out!
The rain helps with the silliness. It's fun being off all week, being shut in because of the down pour and eating junk food and drinking wine!
I did a little math. So far (we have two more days of it) we have gotten 5 inches of rain here (my rain meter says so). Our annual rainfall is 14 inches. With the size back lot I have that mean it would have collected/absorbed/flowed off 62,334 gallons of water since monday evening! And the fireplaces and wine collecting/absorbed/flowed is going great too!
Bored!
You have a rarity there. That device and other similar ones were wired into the alternator to get approximately 120 volts AC. But the frequency varied with engine speed. With a 40 amp alternator you could get about 500 watts of 120 volt AC. They were good for operating lights, small electric percolators, and things like small drills, fans, and vacuum cleaners with universal motors.
If you want to use it, I suggest you use a test meter to check voltage, and then check frequency to see what engine speed you need to get 60 hertz. Often vehicles equipped with these had a remote cable throttle control to hold a set engine speed. But be careful what you plug in - many of these were not fused, and an overload could fry the alternator.
Lots of people looking for info on that little gem, but not getting much.
This one puts out 3kW continuous. http://www.fabcopower.com/generat/bgen.htm
Kind of hard to see, but it looks like the big red wires going into the box are coming straight off the solenoid (battery). Is it possible someone is just using a 120v receptacle as a place to plug in 12v emergency lights (like a droplight)? Have you traced out the wires? That would tell you in a minute.
When I lived in the great white north, pre-EFI, it was fairly common to put electric dipstick heaters, battery warmers, and even plain old hotplates on vehicles at night. If there is a 120v cord going in to the box, it would just be a convenient place to plug all that crap in.
teds74ford
139
10-08-2017 12:46 PM
madsonp
05-20-2017 05:51 PM
Aussie 53
16
04-25-2017 09:57 AM
Fat Diesel
43
12-24-2016 02:14 PM
jayro88
19
02-15-2016 04:23 PM
