Bought a cummins today
Im a new member to the forum and i joined because other then the dodge i just bought i have nothing but fords. The reason for this post is i was wondering if anybody has a powerstroke that runs this hard with only a few mods. Its a 1997 with 143,000 miles, 410's, a five speed with a banks stinger plus kit and the fuel plate completely forward. During the test drive on the loop back the guy told me to take a right that led to a 11% and get into her. Well before we hit the top of the hill i was in fifth gear at 75 mph and boosting at 38 psi. Can u say pucker factor. I was impressed considering the truck can only hit 78-80 mph. This is my first diesel and to say the least i am impressed.
I have a buddy whith a 01(i think) PSD and we had a suburban on a trailer, easy 10,000lbs and it pulled a 6% on our rout like it wasnt even there. I dont know what he has done to it but i know that the PSDs have ALOT of go.
Ya i have a budy whos a psd nut. Between him, his dad, and his mom they have a 94, 01, 04, and an 05 plus 2 6.9's. And iv driven all of them and the 03 and 05 both have a 6 gun bundles and the 01 has a 120 hp box and the 94 has a 60 hp banks chip and even he grinned when he got behind the wheel of this truck. And i know they can match the horsepower and torque but the boost this this dodge puts out blows my mind.
yah any deisel truck will run that hard with a tuner. my friend has a 7.3 powerstroke with an 80 hp chip and it will run, it won't keep up with the dmax with a 70hp tune. the days of dogs and diesels being put together are over. deisels will lay a whooping on any gas motor $ for $ investment wise.
As far as these moded diesels go, to say there impressive is an understatement!!! Why have a mustang or vett when you can have a 7000lb truck that'll run cirlces around them, well maybe not circles but in a drag race anyway.
Like DOHC Marauder always says--Aside from forced induction there is no magic in a diesel. (Sorry Marauder-you know you were thinking it! ) I say that if the big 2 1/2 started putting 8-10 lbs of boost through every gasoline powered intake they made.........peoples views on diesels would change. Just my thoughts on the matter.
Those that think they can just "bolt on a supercharger"...you're dreaming. With stock internals, you can't run more than 8-10 lbs of boost which might get you 100 HP. You'll still be about 150 lb/ft of torque shy of a modern stock diesel and you're engine will be toast after 50k miles. Sure, you can beef up the internals, but there goes your 4-5k you saved buying a gasser.
The "magic" in a diesel is in the cumbustion precess itself. You simply can't boost a gasser and keep the EGT's as low as a diesel....if you do, keep a fire extinguisher handy.
I see what you are saying, but your post is kinda eggagerated. Take a stock 5.4 mod. 300hp@5k--365tq@3750 Ford 6.0 psd is 325hp and 560tq. That's already heavily boosted. Now, run 8-10 lbs of boost in the 5.4(it can be done, think Lightning) and your numbers come out a lot closer to the PSD. Higher horsepower than the diesel but not quite as much torque. Still, when you have nearly 500 lb/ft of torque it's a moot point. The diesels are not even close to doubling torque per liter. They will last just as long as a N/A engine as well. Look at the GM 3800 S/C.It's an everyday reliable supercharged engine. Beefing up the internals of the 5.4 to compensate for mild boost would not cost 5k dollars per engine. The supercharger itself may be different story though.......
I guess it boils down to the age-old question of exactly how you are going to use your truck. The person who just has a boat and a pop-up camper and occasionally hauls loads in the bed will need a different beast than the guy who pulls 5th wheels up mountains.
See you on the boards. ….
BTW
