Wind wing adjustment
Blue -
Do you have a Shop Manual? The process is described nicely in my 56 manual, but the vent windows are different from yours.
You should have some adjustment for the divider bar at the top of the door by loosening the attach screws. Adjust it so that the vent wing will close and the window will still slide nicely. That's my guess based on my 56.
I didn't replace the glass or anything other than the divider bar and it is identical to the one that came out. I was able to get one windwing adjusted to close today. It is very tight, but just does clear the divider bar. The passenger side I have tried everything and although I was able to get the windwing to seat better, I still need a little more adjustment.
Boss_hoss
1999 to 2016 Super Duty
04-04-2011 04:03 PM
