Clutch Problem
Old 09-24-2005, 03:53 PM
johnsdiesel's Avatar
johnsdiesel
johnsdiesel is offline
Thanks for the help everyone. I ended up just having a friend of mine drive me to the Ford dealer to pick up the part, and fortunately for me it was only the bushing. I can't believe that crappy piece of plastic cost me $10, but at least the problem was solved for $10.
Old 09-24-2005, 04:10 PM
cookie88's Avatar
cookie88
cookie88 is offline
Good deal. Glad you're back.
Old 09-24-2005, 05:09 PM
RedStroker6's Avatar
RedStroker6
RedStroker6 is offline
so the rod had popped off?
Old 09-25-2005, 12:36 AM
johnsdiesel
Yep. Once I had the part it was literally a 10 second fix.
Old 09-25-2005, 12:38 AM
RedStroker6
yeah....when it happened to me, it took my probably an hour and a half (probably more...) to figure out what had happened...once i did, yep, 10 minutes to drill and stick a pin in there....good deal, glad ya got it figured out n fixed!
Old 09-25-2005, 11:18 AM
chapguy's Avatar
chapguy
chapguy is offline
I did the cotter pin trick on mine too. A couple of washers, a quick hole and it works just fine. I had to use what was left of the bushing cuz it got mangled the first time I replaced it and stepped on the clutch. The post where the bushing fits was worn on the backside and the bushing slipped right off and disintegrated. 15K miles and it looks and feels like brand new.
Old 10-17-2005, 09:51 PM
johnsdiesel
OK, I'm having clutch problems again, but something new this time. When I came home tonight I pulled up to a stop sign, stopped, and when I went to go the transmission popped out of gear. When I put it back in gear it made grinding sounds. The clutch itself was replaced about 70K miles ago and I just replaced the bushing recently. The clutch pedal is working fine. Throwout bearing? If so, has anyone changed it and how do I do it? Thanks.
Old 10-17-2005, 10:06 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
How about the throwout bearing carrier bending?
Old 10-17-2005, 10:14 PM
barebackjake's Avatar
barebackjake
barebackjake is offline
check to see how much its moving in the bushing. check the bushings that hold the axle in the housing. look for cracks when the pedal is pushed down. check your fluid. what does it look like, cloudy, sparkly stuff in it?
how far down is pedal engagement?
kinda sounds like you didnt have the trans all the way in and when you went to put it back in it bumped the syncros around when it popped out.
it could be the throwout still but not convinced. sometimes you can get a little grease on the shaft and it helps it out. the tranny has got to come out and it just slides on the shaft align it with the tool and put the tranny back in. i really like that kevlar bearing that southbend uses it last longer and its smoother.
Old 10-17-2005, 10:57 PM
johnsdiesel
Keep in mind that I've never done my own transmission work so if anyone has pics that would be great.
barebackjake, fluid is fine, pedal engagement is/was normal, and I had the clutch fully depressed when this happened.
Kwik, is there any way to diagnose this without pulling the tranny?
Old 10-17-2005, 11:08 PM
Kwikkordead
Not without being very familiar with where the fork sits normally if you removed the slave cylinder. The height difference would be very slight and I am not familiar enough to be able to help in that regard.
Old 10-18-2005, 09:46 AM
barebackjake
sounds like it just didnt make it in all the way. if it dosnt do it again i wouldnt be real worried about it. might be just gettting time for a fluid change. the slave is supposed to have 11mm of travel.
so the pedal feels the same? alot of times if the pilot bearing is sticking the pedal gets hard. or it will squeel.
  #28
Old 10-25-2005, 09:42 PM
johnsdiesel
Well, this wasn't what I expected at all. The clutch, transmission, and fluids were fine. The bolts on the rear driver's side hub sheared off somehow. I have no clue how or why and the shop that did the work for me had never seen this happen before. Because of the price, I had them swap the old rear axle with a rebuilt rear axle. I appreciate all the help though guys.
  #29
Old 10-25-2005, 10:45 PM
Kwikkordead
They must have been loose. I've seen it a lot on CV flanges if the bolts are not properly torqued. I'm surprised that you didn't see any oil coming out.
If they were all tight and still broke off all eight like that - well that's a new one on me.
  #30
Old 10-26-2005, 04:57 PM
cookie88's Avatar
cookie88
cookie88 is offline
Can't wrap my brain around how that could have happened. Let's hope it was a fluke.
dalberti
04-19-2015 09:51 PM
TyBragg
50
01-28-2014 07:29 AM
4inchlovin
02-24-2012 05:06 PM
1999SuperD
06-09-2010 10:46 PM
thumper
01-30-2000 04:20 PM
Quick Reply: Clutch Problem
