1998 F150 4x4 motor problems! HELP?
Hello all,
This is my first time posting and I own a 1998 Ford F150 4x4, 5.4l ext. cab stepside... My truck for the last couple months has had a bad miss in it when driving it and I cannot figure it out. This truck just started doing this after I let it sit for 2 wks while I was out of town.
It runs smooth and fine and does not buck when driving above 2rpm's or so but when it is below 2rpm's then it jumps & bucks a little like it has a miss and feels like it tries to run on 7 cyl. instead of 8... It also does not have as good throttle response when sitting at idle then it use to. And it seems to run a little smoother at night time when it is cooler outside which is wierd.
In the last couple months I have tried to fix it by installing a new set of plugs (which was a big headache), along with testing all of the individual coil packs. I took it to auto zone and they did a diagnostic check for me and it came back as a catalac convertor problem which they think it needs a new set of oxygen sensors.
If anyone out there has had this problem before or knows how to fix this, then please help me out.. Thanks in advance!
(Click Here to find out why email addresses are removed from posts.)
CMB1998
Modular V10 (6.8l)
03-23-2013 02:52 PM
BuckTruck
01-05-2011 04:18 PM
jduplan
1997-2006 Expedition & Navigator
07-23-2006 02:06 PM
azhirise
11-17-2000 11:31 PM
