re-setting PCM -'01 4.2
Old 09-13-2005, 11:09 PM
paul812's Avatar
paul812
paul812 is offline
has anyone tried pulling the PCM fuse for 5-10 minutes to reset it? i don't see why this wouldn't work, but i've never heard of anyone trying it. If not, are you supposed to pull the positive or negative battery terminal? thanks....paul
Old 09-14-2005, 05:16 PM
lancekilgore's Avatar
lancekilgore
lancekilgore is offline
It should work, but from what I read everyone just pulls the neg cable off for about five min. if you undo the positive before the neg cable you run a chance of shorting the wrench and causing a spark that is why you do the neg cable. you can touch the body all day with the wrench and it won't spark.
Lance
Old 09-14-2005, 08:21 PM
triton_2002's Avatar
triton_2002
triton_2002 is offline
I would leave the battery disconnected for at least 15 min. and turn on the headlights to drain the electrical system. And defenitley pull off the neg. cable as suggested above.
