Gas Gauge Short?
Gas Gauge Short?
Greetings,
High gas prices? Doesn't matter, mine is always full!!!
When switched to my rear tank, truck runs fine and continues to run, I believe I have about a half tank. The gauge reads over full, as if it's shorted. Is there an easy fix or check that I can do without dropping the tank?
thanks!
Walt
'88 F250 7.5 reg cab 4x4
thanks!
Walt
You can always run a volt meter to check your wiring & gauges.
But with a 88 model, more then likely it is a bad sending unit in the tank. Those model year of Ford F-Series are notorious for the problem.
So I would say....
Replace the sending units or just calculate you MPG using the odometer & using smarts to figure where your gauge should read.
So I would say....
That is just a recommendation based on what I had to do. I thought I had a faulty pump...when through everything...except replacing the pump. Only to find out my switch had gotten hot and melted. The gauge worked, but the pump didn't, either tank. I spent a lot of time trying to figure out the problem. Now I always start at the switch.
