gear swap ?'s
you have 3.08 gears, a 4R70W transmission. I can't find the final drive ratio on that transmission, but I'll just say in 3rd gear at 1:1 trans ratio, going 60 mph you are at around 1700 RPM with of course a 3.08:1 ratio.
A 6 cyl needs to run in between 2000-3000 at highway speed (not in OD).
With 4.56 gears at 1:1 (3rd) you should be just above stock feeling and around 2600 RPM at 60 mph and around 1800 overdrive rpm, so either 4.10's or 4.56's would be best depending on what you want, 4.10's will give better fuel mileage while 4.56's will have a bit more pulling power.
Originally Posted by johnsonswamp
Never heard of a 4.30 ratio, but that would put you in the best of both, power and fuel mileage. With either ratio you won't be "wound out" at 70 mph, it will be just like it was with stock tires.
The 4.56's should have a tad more power than it did when stock, not sure what tires you are running but as long as their not a heavy tire (i.e. bogger's) then it will be perfect IMO.
I wouldn't go above 4.56's unless you want to watch your gas guage drop fast every trip.
I have 35s on my 02 FX4, stock 3.55 gears. Adding the 35s lowered the ratio to about a 3.25gear ratio. I am getting ready to put a set of 4.10 gears on the truck. My truck does the same thing, just alittle sluggish with the bigger tires. 4.10 gears with 35s will be the equivalent to 3.73s which is a good well rounded gear for mileage, power, and towing.
TinyG F150...what kind of RPMs are you turning now going to 4.56s? For Ex: at 55,65,75mph, whats your RPM? Debating 4.56s on my 02 FX4 5.4L with 35s after alot of you opting this route, sounds like everyone is happy with them. I have stock 3.55s and was gonna go 4.10s...maybe 4.56s is a better choice. I was just worried about my motor winding too high for a daily driver.
#28
My speedometer is pretty bad off but running along with traffic on I-24 ( usually around 75-80mph) Im running around 2200-2500 rpms. I had the same concerns about 4:56's winding out being an old Stang guy 4:56's sounded crazy but I am so glad I went with these gears. My truck had 3:05 gears so the difference will not be quite as drastic on yours going from 3;55's.
