2000 4.2 v6 problem
2000 4.2 v6 problem
i own a 2000 ford f-150 v6 5spd with 105,000 miles on it. when i'm accelerating or going uphill the engine seems to skip. it doesn't do it all the time. i changed the spark plugs and wires in it. it seemed to fix it for about 2 weeks then it started doing it again. i took those plugs and wires out and bought some more plugs and motorcraft wires and it seemed to fix it for about 2 weeks also. i have no "service engine light" or anything. my cousin has a 1998 f-150 v6 5spd and his does the exact same thing. has anyone had this problem with their 4.2? if so, how did you fix it? thanks for the info.
-matt
-matt
Originally Posted by Matt_W
If replacing the wires and plugs fixed it for a short while it might be worth checking the coil pack. If its weak it could make it seem like the wires or plugs.
I've had a dealer do a WDS scan and apparently I'm nuts. My truck is running fine.
Good luck,
Rich
did you try cleaning your maf/tb and iac? pull your rear two plugs again and check the condition see if they have deposits built up? motorcraft plugs make my 3.8 mustang run like crapola, try autolites if you have to replace. you might want to also pull your o2 sensors to check the condition, might be able to clean them by burning off the carbon with a torch, replace your pcv and fuel filters if not already done. good luck
i put a new fuel filter on it and it didn't seem to help. when i bought the truck the first thing i did is replace the spark plugs and they are autolites(it had the problem when i bought it).it seems like it is some sort of sensor or something that is causing my problem because it really doesn't skip- it misses, kinda like the engine dies for a second, so i don't think it has to do with the plugs, wires, etc. i will check the things you suggested 99mustang232- thanks for the info
-matt
-matt
this sounds like a problem I had with my ranger, as well as two other trucks that belonged to some friends. we found that our problems were all the same, and easy to fix. while you're under the hood checking all these other possibilities posted, check the wires in and out of the fusebox under the hood. when the three of us had this problem, the negative wire from the box to the battery was loose. it would cause the trucks to miss pretty bad.
