1988 Bronco II headlight problem
08-17-2005, 10:38 PM
on
I can't get the headlights to work on this vehicle, I've replaced the swith, but no luck, Help!
08-17-2005, 11:56 PM
08-18-2005, 05:30 PM
If it's wired the same as my 87 You need 12 volts on the red/yellow wire from the dash switch to the dimmer switch.
Which switch did you replace.
Have you got a wiring diagram?
08-18-2005, 07:24 PM
on
I replaced the pull switch on the dash, and I purchased a headlight/power door locks relay, but I can't find the old one to install it.
08-18-2005, 08:19 PM
Are you sure this has a headlight relay?
Take a look a Autozone.com for an online wiring diagram.
If theres no relay, you need to pull the plastic shroud off of the steering column & check voltage at the multifunction/dimmer switch.
shelbyhats
11-19-2016 08:26 AM
cliffhanger228
09-02-2015 04:59 AM
Bigbruce
WTB - Ford Trucks & other vehicles
08-13-2012 08:53 PM
bgreen
2009 - 2014 F150
11-12-2010 11:55 AM
HowieE
Electrical Systems/Wiring
11-11-2009 11:07 PM
1988 ,
87 ,
88 ,
bronco ,
ford ,
haedlamp ,
head ,
headlight ,
ii ,
light ,
location ,
problem ,
problems ,
relay ,
wiring
