having problems can any one help me ?????
It's usually one of two things. Either the EGR port in the intake is clogged or the DPFE sensor is bad. Most common is the sensor, but if the engine has alot of miles on it, you may check the EGR first. At an idle, apply direct vaccum to the EGR valve. The engine should stumble and even die. If not, the the ports are clogged. If it does bog or die, then the sensor is bad.
the auto zone place told me that that the egr valve could be defective and or the egr pressure sensor. how would i apply vacuum pressure to the egr valve to see if it is bad ? im kinda new at this thing so you might need to break it down barney style for me to understand sorry.also what is the dpfe sensor? they didnt say anything about that ?
That is the EGR sensor. It tells the PCM if there is EGR flow or not. It usually has 2 lines that are attatched to the EGR tube running up from the exhaust to the EGR valve.
You can hook up a vacuum hose to the EGR valve and suck on it really hard. That should be enough to open it to see if the idle changes. Or you can use a hand held vacuum pump which can be purchased at most auto parts stores. It works great for bleeding brakes by youself too.
I believe that is exactly what just went on my F150. I was in FL @ the time and engine light stayed on. My original dealer checked it and advised me the sensor went and I got it replaced in GA when I got home. Mine went at 22K miles which is not normal. Usually they go around 60K I believe.
